XPEDO R-FORCE TI/TI TITANIUM ROAD PEDALS ...159 gms per pair
eliflap-scalpel
by eliflap-scalpel
uraz wrote:Xpedo Thrust 8 Ti
cannot see image
http://eliflap.it/
uraz
by uraz
It should be visible now.
eliflap-scalpel
by eliflap-scalpel
yes ,
http://eliflap.it/
andreszucs
by andreszucs
Got these so cheap...gave me room to play around!
Tuned R-force with new grease, light bearings....light KCNC chainring Nut to the spindle and Proti FFR tension adjuster bolt
bas
by bas
Thread mining here, but how did they go as a MTB pedal?
I often wonder how much harder a single sided pedal would be to manage if it actually hung at the correct entry angle like road pedals do.
andreszucs
by andreszucs
bas wrote:Thread mining here, but how did they go as a MTB pedal?
I have mixed opinions on this. If you ride places where you know you are going to stop often specially in challenging hills when take off is hard, or those near impossible sections ....these are not ideal.
In other words is the kind of weight saving with some small sacrifice.
Marin
by Marin
I ride similar, 1-sided Ritchey Micros on the road.
For MTB or CX I'd go double sided unless low weight was top priority.
rickyloh
by rickyloh
Hi Guys,
I just bought a Xpedo R-force Ti-Ti clipless pedal which is old version with 1 sealed bearing and 1 DU bearing.
Would like to ask if the DU bearing will affect our performance? I'm asking because the pedal seems to be quite tight when spinning.
Can I upgrade to all sealed bearing myself? If yes, can you guys recommend which bearing (size/ model) to use?
Thanks in advance.
Klaster_1
by Klaster_1
andreszucs wrote:
Sat May 30, 2015 8:43 pm
How have the pedals held up since 2015? Were KCNC chainring bolts enough to protect bearings from elements? Do you remember what torque was used for the chainring bolts? How's bearing life, were these hybrid ceramic?
Klaster_1
by Klaster_1
Apparently, my revision of R-Force Ti uses fasteners unlike shown in earlier posts:
XPEDO R-Force Ti partially disassembled
The cross screw did not budge and I dared not to strip it. Maybe there's a trick to it? Plastic cap deforms easily.
Marin
by Marin
Did you turn in the right direction? One side will have a left hand thread, don't ask me which one :D
PokojniToza
by PokojniToza
Very unfortunately named pedals.
Marin
by Marin
Why?
PokojniToza
by PokojniToza
Like a former pedophile, who needs to register. Bad joke, carry on:)
Klaster_1
by Klaster_1
Marin wrote:
Sat Jan 19, 2019 7:24 pm
Maybe not even that, this video says that Wellgo CroMo spindle nuts are right/left threaded, but Ti spindles are right threaded. I inquired Xpedo for service info and will report here when they reply. If both screws are regular right threaded, I'd try to replace these with Ti. Chances are slim I'll be able to find a left handed Ti screw. I wonder why Xpedo did not make all the steel parts out of Ti: springs, spring tension bolt, spring axle, inner race bolt are all steel, quite a bit to save if you have access to right tools to manufacture replacements.
