Where do you see the 2/3 and 3/3 available? I can't find anything other than the 1/3 on Assos' site.
Assos apparel questions
I suggest that you send it to ASSOS or bring it to one of our stores for assessment (or they can send it in). Sorry to not be of more help.GaBa wrote: ↑Wed Feb 20, 2019 10:50 amI also have a question for @RTW regarding skinfoils, specifically their length. I have spring/fall skinfoil with short and long sleeves, version with two white lines on their sleeves. And also winter skinfoil 6/7, all of them in size I. They are all sufficiently long. Now I bought early winter skinfoil (3/4) with turtle patern on one sleeve and this one is considerably shorter. I also compared it with my wife's size 0 old iteration (two white lines on sleeves) and mine was shorter than her's. I have to stretch it a lot when getting dressed in order to be able to stuff it under my pants but I can't stop to wonder if this new "length" is normal or did I receive a defected skinfoil?
I don't think they're out yet, just the older 2/4. But I'm sure they'll be available when before the season starts.
- Factor Ostro VAM Disc
- Factor LS Disc
- Specialized Aethos Disc
- Sturdy Ti Allroad Disc
- Guru Praemio R Disc
- Factor LS Disc
I already did that but had no "success". We compared size 0 and II of early winter skinfoil and 0 was not much shorter or even the same while II was only slightly longer. But in general II is too big for me. Lenghts are just a bit confusing to me right now but ok, I just stretch mine and stuff it under my pants, which then hold it in place - seems to work. While in shop I saw that new hot summer skinfoil in black is also very short, but again stretchy, so should be able to lenghten it and put it under pants as well.RTW wrote: ↑Thu Feb 21, 2019 2:17 pmI suggest that you send it to ASSOS or bring it to one of our stores for assessment (or they can send it in). Sorry to not be of more help.GaBa wrote: ↑Wed Feb 20, 2019 10:50 amI also have a question for @RTW regarding skinfoils, specifically their length. I have spring/fall skinfoil with short and long sleeves, version with two white lines on their sleeves. And also winter skinfoil 6/7, all of them in size I. They are all sufficiently long. Now I bought early winter skinfoil (3/4) with turtle patern on one sleeve and this one is considerably shorter. I also compared it with my wife's size 0 old iteration (two white lines on sleeves) and mine was shorter than her's. I have to stretch it a lot when getting dressed in order to be able to stuff it under my pants but I can't stop to wonder if this new "length" is normal or did I receive a defected skinfoil?
Appreciate your help anyway
Good to know. thx for that.
- Factor LS Disc
- Factor LS Disc
yeah, fit wasn't or didn't seem correct when the SkinFoils came out. I transitioned from the earlier baselayers (not SkinFoils) and figured they would or should fit the same. The sleeve lengths were all over the place...I can wear a size I or size III without much difference with the exception of the material bunching up a bit more with the III. They both fit regardless. Now, with the newer ones coming out...I can wear size 0 without any issues. I don't think you got a defective SkinFoil...its just the nature of the beast. Tons of stretch in the more insulated versions than the warmer versions with mine.
GaBa wrote: ↑Sat Feb 23, 2019 11:06 amI already did that but had no "success". We compared size 0 and II of early winter skinfoil and 0 was not much shorter or even the same while II was only slightly longer. But in general II is too big for me. Lenghts are just a bit confusing to me right now but ok, I just stretch mine and stuff it under my pants, which then hold it in place - seems to work. While in shop I saw that new hot summer skinfoil in black is also very short, but again stretchy, so should be able to lenghten it and put it under pants as well.RTW wrote: ↑Thu Feb 21, 2019 2:17 pmI suggest that you send it to ASSOS or bring it to one of our stores for assessment (or they can send it in). Sorry to not be of more help.GaBa wrote: ↑Wed Feb 20, 2019 10:50 amI also have a question for @RTW regarding skinfoils, specifically their length. I have spring/fall skinfoil with short and long sleeves, version with two white lines on their sleeves. And also winter skinfoil 6/7, all of them in size I. They are all sufficiently long. Now I bought early winter skinfoil (3/4) with turtle patern on one sleeve and this one is considerably shorter. I also compared it with my wife's size 0 old iteration (two white lines on sleeves) and mine was shorter than her's. I have to stretch it a lot when getting dressed in order to be able to stuff it under my pants but I can't stop to wonder if this new "length" is normal or did I receive a defected skinfoil?
- Factor LS Disc
- Factor LS Disc
Sorry to hijack your reply. Just wondering if you have experience with both s7 and evo7 skinfoils (for colder weather), and any significant difference between them? I have the older s7 versions, and am considering whether if it's worth getting the evo7. Thanks!kode54 wrote: ↑Sat Feb 23, 2019 7:02 pmyeah, fit wasn't or didn't seem correct when the SkinFoils came out. I transitioned from the earlier baselayers (not SkinFoils) and figured they would or should fit the same. The sleeve lengths were all over the place...I can wear a size I or size III without much difference with the exception of the material bunching up a bit more with the III. They both fit regardless. Now, with the newer ones coming out...I can wear size 0 without any issues. I don't think you got a defective SkinFoil...its just the nature of the beast. Tons of stretch in the more insulated versions than the warmer versions with mine.
The material weave is different. If you like the S7 version, no reason to go evo7. However, summer version is more ventilated if you need that.
- Factor LS Disc
- Factor LS Disc
S7 goes all the way to 7 while the Evo/ goes to 4, right? I have from both, and the earlier are mostly stiffer. IIRC sizing steps are different too: Evo7 has four steps whereas S7 had three.
Thanks! It seems that even the material is the same (e.g. for early winter) but the weave can be different. Probably not much of difference in terms of performance.
