DIY Di2 sprint shifters
Beancouter
by Beancouter
Grouk - for the climbing shifters do you have 2 for up and down the rear cassette? If so, can you please let me know how they are wired in.
Also, did you use the specific sprint shifter wires plugged into the bottom port of the shifter (which I believe has a different port) or a standard e tube cable).
Thanks
grouk
by grouk
in the climber shifters i have in the left 1 shifter that up in the cassete and in the right i have 1 that down in the casssete, i bought i normal cable cut in half plug in the port in shifters that is diferent then the others, two are rounf and one is round and have a cut. that is a port for a normal on of switch. use that
I'll put the best photos and draw a diagram
grouk
by grouk
Beancouter
by Beancouter
Thanks really helpful - many thanks.
aaric
by aaric
Given the leads are 200+mm, is there an easy way to connect to the ribbon after cutting them shorter? Soldering seems to melt right through the ribbon.
alanmclean
by alanmclean
Thank you for sharing this great idea. I am not very good with electrics so would prefer to use the Shimano own brand "sprint" buttons for climbing buttons if possible. Are the leads long enough to reach the top of the bars or do they only reach the drops for real sprinting? Anyone measured the leads please?
I see Shimano sell a two way Roubaix/climbing switch for top of the bars but it looks a bit bulky and I would like cool small buttons like the pics above.
Many thanks
Alan
goodboyr
by goodboyr
He's using the sprint shifter ports to connect the switches. Those ports accept "dumb" buttons, but only operate the rear derailleur.
grouk
by grouk
Sprinter switch only operate rear derailler but you could hack the left shifter and ad buttons
Enviado do meu DAGGER DG550 através de Tapatalk
djqgmffj
by djqgmffj
wow goodjob
jaedan23
by jaedan23
wow... Awosome!! I'll try to DIY...
svarteld
by svarteld
Hello,
Great info here, thanks.
I've got a question: is it possible to use the 7970 system without the road brake shifters, and only plug multiple diy simple inline switches into the top junction box? I'm looking to build a custom setup 1x10 for my tempo bike without the shimano shifters, be it road or tt, just the cateye switches.
Thanks
goodboyr
by goodboyr
Yes. No problem doing that. Do a search for the colour coded wiring diagram for reference.
svarteld
by svarteld
Many thanks! I will.
CallumRD1
by CallumRD1
Does anyone know if this can be done in any way on the newer Ultegra 8070 or Dura Ace 9170 hydraulic Di2 shifters? As I understand it, they don't have the dedicated sprint shifter port but they do have a free normal port.
Multebear
by Multebear
Does anyone no of a link to buying those exact buttons that OP is using? I've found numerous buttons on ebay, but they are either to big, thick or wrong in some other way. I was considering them for the TT bike.
