DIY Di2 sprint shifters
strangely
by strangely
@AndrewL, if you have a Garmin 510, 810 or 1000 (or some of the newer watches), then if you are going to upgrade then I can really recommend the DA9070 brifters since they could then also remote control your Garmin if you also have the D-fly wireless unit. Its a great feature to have!
grouk
by grouk
d-fly also works with 6870
aaric
by aaric
Yes the D-Fly works with 6870/6770, but the remote buttons on the top of the shifters only exist on the 9070s, which is one of the coolest features of D-Fly integration in my opinion.
I've actually gotten somewhat addicted to being able to page using them. The paging also serves as a one click way to exit the configuration menus, that I use at the beginning of the ride to calibrate my power meter.
You get 4 options to program. Short and long press for each side.
grouk
by grouk
i think the lap button is a great function
eliflap-scalpel
by eliflap-scalpel
a question:
connecting the sprinter shifters directly to the junction under the stem, does the shifting function work ?
without the Shimano shifters, I mean.
http://eliflap.it/
rmerka
by rmerka
The spint shifters or other momentary switches need to plug into the dedicated port on the 6870 or 9070 shifters. the controller that operates them I believe is tied into that specific port which is why the port is keyed.
eliflap-scalpel
by eliflap-scalpel
thanks rmerka , for the presence of the PCB .... but someone had tried to plug ?
http://eliflap.it/
scamper996
by scamper996
Hi guys, I got the diy sprint shifters to work but they only shift down. I like them to shift up more for climbing on the tops. Am I doing something wrong and only the bottom port on the right shifter works 9070. Thanks
Sent from my 2014817 using Tapatalk 2
grouk
by grouk
you need to configure with etube software
scamper996
by scamper996
Ah yes forget you could do that , cheers
Timujin
by Timujin
would love to be able to control at least the lap function on my garmin from the hood area, but i have campag shifters...
sparelink
by sparelink
Anyone else having issues with the pictures?
Jesper64
by Jesper64
grouk wrote:i use that setup a year a go, first i use a normal switch buy at local eletronic shop, first time in the rain start failure
then i buy a better switchs and i put it inside a round plastic piece, like that i can put tape above the switch, with the tape it becomes waterproof.
for the climbing switchs i use a flat membrane switch,now my setup is perfect and i love it
Where did you get those membrane switches from?
Jesper64
by Jesper64
