You can just buy a SD300 cable and cut it, and use the two ends as "new" connectors for you old R610
I just did this, and it works perfect. The new Shimano version has a special connector but is is just a SD300 with an extra flange to prevent people to plug it in the wrong hole. The SD300 connector fits fine.
DIY Di2 sprint shifters
Thanks for the confirmation, which di2 shifter do you have?LAN wrote: ↑Tue Sep 20, 2022 1:01 pmYou can just buy a SD300 cable and cut it, and use the two ends as "new" connectors for you old R610
I have two bikes both with ST-R9270 shifters
On bike nr. 1 I have spliced two old sets of SW-R610 with a SD300 port. So both climb and sprint button per side in one port.
On bike nr. 2 I have spliced an old set of SW-R610 and an old set of Cateye button with a SD300 port.
Both setup works perfect. As long as you use the lowest slot on the shifter, the signal i just a dumb on/off switch.
