Bora Clinchers; run 23s or 25s?
cmcdonnell
by cmcdonnell
wonkeu wrote:i prefer 25mm to 23mm. if you are not a professional rider, it might be safer than 23mm. just in my experience.
Safer? How do?
Bianchi Oltre XR2 + Campagnolo Super Record 11 + Campagnolo Bora 50C
Litespeed T1 + Campagnolo Chorus 11 + Campagnolo Shamal Ultra
danbjpa
by danbjpa
i think 25mm be safer for rim in puncture case (less exposed to grind on tarmac)
jacobeh
by jacobeh
Sorry to be bringing up an old subject, but I recently got a pair of Bora 50's and used this thread for deciding what tire to buy and went with the Conti 4000s II 23mm, but contrary to previous poster's experience, mine only measure 23.8mm at 100 psi. Does anyone know if Conti has made changes to this model since this thread was made? If so, their 25mm model might be of interest if it is more closely to 25mm than previous.
sawyer
by sawyer
jacobeh wrote:
Thu Jan 18, 2018 10:04 pm
As a bonus the pair only weighted 199g and 208g respectively compared to the official 215g.
No changes
Nohands83
by Nohands83
I’ve just put a set of the new (wider) attack / force on my bora 35s and they measure, 25.40mm front and 26.7mm rear. So pretty much what you’d expect from Conti’s. Was on a set 25/28c set of Vittora corsas G+ previously. The attack / force weighed in at 370g for the pair so took a cool 155g off in the process. Will see how they ride at the weekend ;)
pdlpsher1
by pdlpsher1
The 23mm on my Bora measures 24.7mm. Perhaps they will stretch a bit after some use. I run 90psi on mine. By the way I run 23mm on the front and 25mm on the rear.
jacobeh
by jacobeh
pdlpsher1 wrote:
Tue Feb 13, 2018 8:02 am
The 23mm on my Bora measurs 24.7mm. Perhaps they will stretch a bit after some use. I run 90psi on mine. By the way I run 23mm on the front and 25mm on the rear.
That's what I've been thinking as well considering I've only used them on my hometrainer so far (Danish winter...sigh)
Frankie - B
Administrator
by Frankie - B
jacobeh wrote:Sorry to be bringing up an old subject, but I recently got a pair of Bora 50's and used this thread for deciding what tire to buy and went with the Conti 4000s II 23mm, but contrary to previous poster's experience, mine only measure 23.8mm at 100 psi. Does anyone know if Conti has made changes to this model since this thread was made? If so, their 25mm model might be of interest if it is more closely to 25mm than previous.
Etrto guidelines state that the size of a tirecan deviate 3mm both ways. So, you struck one from a badge stat is close to the size.
