AX Lightness Vial EVO
the fit is tight with 25mm up front. rear is okay. running Schwalbe Ones.
- Factor 02 VAM Disc + DA9170 + Enve 4.5AR CK CL hubs
- Moots Vamoots Disc RSL Titanium + DA9170 + Enve 3.4AR CK CL hubs
- Factor LS Disc + DA9170 + Enve G23 CK CL hubs
- Repurposed Guru Praemio R w 3D disc dropouts + DA9170 + Enve G23 CK CL hubs
- wheelsONfire
I would like to ask all of you who own Vial EVO (D).
Imagine you'd buy an aero bike or frameset, what would you look for and why?
What would you rid of your list and why?
Bikes:
viewtopic.php?f=10&t=156137
Open *UP* (2016.04.14)
Ex bike; Vial EVO D
Ex bike; Vial EVO D
- wheelsONfire
kode54 wrote:the fit is tight with 25mm up front. rear is okay. running Schwalbe Ones.
Aha, you use clincher version i understand.
No wonder it's tight with those wide clincher rims.
Tub version is 22-24-26-28.
I run 24mm tubs and it's not a problem at all (rim 26mm).
Bikes:
Ex bike; Vial EVO D
Ex bike; Vial EVO D
wheelsONfire wrote:I would like to ask all of you who own Vial EVO (D).
with the Enve SES 4.5...its actually not too bad. feels better at speed than the Enve SES 3.4. anything over 20mph.
- wheelsONfire
AZR3 wrote:Anything extra needed to run a Rotor 3D+ on this?
2*2.5mm spacers, one on each side.
Bikes:
Ex bike; Vial EVO D
Ex bike; Vial EVO D
- wheelsONfire
Any one of you guys running EPS on your Vial EVO?
Bikes:
Ex bike; Vial EVO D
Ex bike; Vial EVO D
BB standards are, for some reason, very difficult for me to wrap my mind around. I currently run a rotor crank on my '09 Cervelo RS which is BSA. If I were to buy the Evo D and swap my stuff over, would I only need to worry about getting the correct BSA to BB386 adapter, or is it way more complicated than that?
Cheers.
Cheers.
Does your crank say 3D+ or 3D30 on it? If yes, its 30mm. If no, its 24mm.
What kind of bottom bracket are you running? If its anything other than a Rotor (e.g. shimano bottom bracket) then it will be 24mm. Rotor makes both a 24mm bb and a special one that lets you run Rotors 30mm cranks on a threaded shell.
Or you could just take it out and measure with some calipers....
The BB is made by Rotor as well, and the model is the SABB BSA Road L. It doesn't list the spindle length, but from what I have seen around the internet it would appear to be a 24mm. The BSA 30mm say on the BB itself, but the 24's don't from what I've seen.
So let's assume that this is the case - What does this mean for adapting it to the Vial Evo's standard of BB386?
Many thanks BTW
Many thanks BTW
tharmor wrote:BB standards are, for some reason, very difficult for me to wrap my mind around. I currently run a rotor crank on my '09 Cervelo RS which is BSA. If I were to buy the Evo D and swap my stuff over, would I only need to worry about getting the correct BSA to BB386 adapter, or is it way more complicated than that?
Cheers.
Rotor doesn't make a 24mm to 386 bottom bracket. They have a BB which allows you to install cranks w/ a 24mm spindle on a PF30 frame (68mm BB shell).
http://www.rotorbike.com/media/files/20 ... 521655.pdf
IIRC, the Vial EVO cups are already pressed in the BB. So this might be the best adapter:
http://wheelsmfg.com/386evo-adapter-for ... ranks.html
Hi
this is my first post although it is a long time since i 've started
following this forum.I have very recently finished building an amazing Vial Evo.
The ride gives you an extraordinary feeling every time but there is something
ruining the whole magic.I have noticed a very small play in the upper bearing
of the headset.This happens no matter how much i torque(not overtorque) the
screw from the headset cap and the ones from the stem.Any suggestions would
be appreciated.
be appreciated.
