slight headset play on Addict R1
addictR1
by addictR1
EM3: wow.. thanks for the info. it's too late now to take everything apart. i'll do that after my ride tomorrow. how can i remove the crown race? is it easy to do or better to have the LBS do it? also, what would be a lightweight headset that will fit the 2009 AddictR1?
oreoboreo
by oreoboreo
+1 for carbon paste. You know I have the same bike and that is what I used form day one. Never have had any challenges. Do you have a thin spacer under your compression cap? I see them below the stem, it is hard to tell from the pics. It is needed to get the torque to actually be effective.
Let's finish the ride with a 20% grade.
2011 Scott Addict R1 DA 7900 Matt black
2012 Scott CR1 Pro Ultegra 6700
2015 Specialized SWorks Tarmac Da 9000
2016 Specialized SWorks Tarmac DA 9100
em3
by em3
addictR1 wrote:EM3: wow.. thanks for the info. it's too late now to take everything apart. i'll do that after my ride tomorrow. how can i remove the crown race? is it easy to do or better to have the LBS do it? also, what would be a lightweight headset that will fit the 2009 AddictR1?
On a carbon fork it is best to have the proper tool...see:
http://m.parktool.com/product/adjustabl ... ller-crp-2
EM3
______________
addictR1
by addictR1
ok, today i got an email reply back from Scott. i thought they would recommend me to get the Ritchey WCS, but i guess not...
Hi,
Addict model year: 2007-2011 absolutely need a crown race between the fork and bearing. I will suggest that you order a complete, new head set and install it, so all parts match. There are some really good bike shops out there, so if the shop says the chamfer/angle match between the ID of the bearing and the angle on the race, I will assume you’re ok. Otherwise, we usually have SYNCROS brand head sets in stock, but are out right now. Within 3 weeks, we’ll have part # 228440 in stock, which is a perfect match for your frame.
Take care,
ben
Ben Chournos
Beschreibung: cid:3352198107_11833084
now the question is.. which is lighter and is this any good?.. cuz i never heard of SYNCROS before. ;)
jekyll man
by jekyll man
Syncros is (was) a Canadian brand famed for making seatposts and stems bitd of the golden era of mtb'ing.
Disappeared years ago, then reappeared a few years ago making cheap imitations of its old products.
Scott then bought the name/ company and now uses it as it's in house brand
Official cafe stop tester
addictR1
by addictR1
jekyll man: thank... guess i'll keep searching some something lightweight that will fit. my scott addict R1 is about 13.65lbs right now with pedals... so if i can save a bit more weight.. the better.. hehe :)
