Hongfu FM-066/Chinese open mould frame thread
icantaffordcycling
by icantaffordcycling
Good call @ paranorml 100% the 007-D now that I look at them side by side.
durianrider
by durianrider
paranorml wrote:
Wed Mar 20, 2019 5:36 am
waltthizzney wrote:
Thu Feb 21, 2019 8:56 am
Does anyone know what Open Mould bike branded "Nove" that Phil Gaimon is riding?
Looks to be a Lightcarbon 007-D
Or a Yishun 007.
My YT channel
http://www.youtube.com/user/durianriders?feature=mhee" onclick="window.open(this.href);return false;" onclick="window.open(this.href);return false;
Follow me on Strava
http://app.strava.com/athletes/254600
none
by none
synthesis wrote:
Fri Mar 15, 2019 11:28 pm
HongFu TM6D is in the works, and looks ace imho.
Looks very nice, please send update with more pictures of cable routing please.
boilerup
by boilerup
Has anyone seen the new frame Yoeleo just released? Looks to only come in disc brakes.
https://www.yoeleobike.com/road-bike-fr ... ke-r9.html
DDX
by DDX
Build complete for a Velobuild VB-R-086.
7kg (including pedals/bottlecages/wahoo mount)
Original plan was to use Bontrager directmount brakes, but rear brake doesn't work on this frame :
So went for the Shimano Ultegra 8010 brakes.
none
by none
Looks like the rear brake cable may extend out from frame to rub against your leg as you pedal?
DDX
by DDX
Rear brake :
Tire clearance (25mm), front :
rear :
HillClimbTom
by HillClimbTom
DDX wrote:
Fri Apr 19, 2019 2:07 pm
What’s your thoughts on it? Why did you go for that frame over any of the other options mentioned on here? Cheers
skyboy
by skyboy
How much do velobuild charge to have a frame painted in one colour like that?
ChristianB
by ChristianB
Hi Weenies,
I am considering treating myself a TanTan TT-X1 / TT-X8 (as far as I can tell, the only difference is the brake system - normal vs direct mount). I will need a size L.
I would be very happy to hear from owners if the geometry measurements on the website are correct, any experiences with their custom paint option, general ride feel and quality. If anybody can post a picture of a Size L build up, that would be awesome :)
Thanks
Christian
DDX
by DDX
HillClimbTom wrote:
Fri Apr 19, 2019 9:34 pm
I wanted direct mount brakes and the geometry of this frame is perfect for me. (54cm frame)
Only issue is the seatpost which is slipping down.
Had the same issue with my other velobuild frame (gravel frame) will be sorted but things like this is why they are chaeper than known brands ;)
skyboy wrote:
Sat Apr 20, 2019 12:39 am
50 dollar for 1 color (I gave Chris the paintcode)
skyboy
by skyboy
DDX wrote:
Tue Apr 23, 2019 12:36 pm
Good value thanks for the info!
About the seat post it's such a common problem. Do you know the best way to fix it and if not please post when you find out.
deepakvrao
by deepakvrao
Very nice. What are the advantages of direct mount brakes? More clearance?
gravity
by gravity
Anyone knows if the swiss brand ARC8 is actually an OEM frame? If yes where can one get one? Thanks!
skyboy
by skyboy
durianrider wrote:
Sat Apr 06, 2019 1:20 pm
Or a Yishun 007.
The Nove Aero rim brake frame is a Yishun R006-V. I like the look of the geometry but Nove charge over $2k for it.
You need to order a minium of 10 to order from Yishun directly. Does anyone know a Yishun re-seller with more reasonable prices?
edit: yoeleo sell it as the R6, still slightly above my price point.
