Hongfu FM-066/Chinese open mould frame thread
Dutchbiker
by Dutchbiker
Hello,
Can anyone tell me something about the quality of these two brake disc frames:
1. Velobuild VB-R-057 - http://www.velobuild.com/2018-new-carbo ... p0107.html
It looks like a copy of the Canyon CF SLX (or it just is a copy). So I guess not really open mould. But I really like the look if it, although I can't find any reviews.
2. DengFu R10 - http://www.dengfubikes.com/ROAD_FRAME/248.html.
Contacted seller and seller says it's an open mould and not based on any other bike.
Both frames can take 28c tires and both can take Di2. The velobuild has a tapered headset. Dengfu has a straight headset.
Can any of you tell me something about these frame or any suggestions whether I should go for the Velobuild or the DengFu (or any other disc brake frame)?
Thanks for your reply!
BiscuitHarrington
by BiscuitHarrington
Dutchbiker wrote:
Fri May 04, 2018 6:00 pm
Hello,
Regarding the DengFu R10 - excuse the n00b question, but how common is a 1 1/2 - 1 1/2 straight steerer? I haven't seen that combo too much, but I could have had my head in the sand.
Dutchbiker
by Dutchbiker
BiscuitHarrington wrote:
Fri May 04, 2018 7:13 pm
Hello,
From what I know a straight steerer is the 'old' style and these days a tapered steerer is the standard, because it has less flex.
Hexsense
by Hexsense
What common is 1 1/4 to 1 1/4 straight, isn't it?
Then bike brands enlarge the bottom to be 1 1/2 so it is stiffer. while keeping the top one at 1 1/4 (so the steerer tube size is 1/8)
Now these are straight 1 1/2 to 1 1/2... Does that imply 1 1/4 steerer tube? Then there are only few stems available in 1 1/4 size, like Pro Vibe Di2 stem which offer in both sizes.
That Dengfu R10 frame looks interesting though. A bit longer chainstay than usual (415mm) for good chainline on disc brake spacing, a bit higher stack than usual racy bike mostly because of longer fork (~2cm longer) to accomodate larger tire and also more bb drop distance than usual (72mm instead of normal 68-69mm). The more bb drop will bring rider down lower to the ground, compensate for extra height the wider tire introduces. 69mm bb drop were normal since road bike were on 19c tires, now we are riding 25c-28c which is a lot taller than 19c of old age, hence more bb drop to compensate it make sense. The frame also have tire clearance for 28c (32mm max) so it clearly design for wide tire. However, isn't that just round seatpost instead of aero seatpost we kind of expect to see from (semi?) aero frame?
wisdom
by wisdom
Hi all,
Can someone confirm if the following headset bearings are compatible with FM-066SL please?
https://www.aliexpress.com/item/Neco-Ex ... 8a11ccc8-1
Thanks
chalkie
by chalkie
wisdom wrote:
Sat May 12, 2018 3:42 pm
Hi all,
Thanks
Should fit all right
LeDuke
by LeDuke
I’ve been less than impressed with some Chinese HS bearings. I’d buy a Cane Creek 110 bearings and be done with it.
patrikantonius
by patrikantonius
Hi and thanks to all the contributors to this information rich thread.
I stumbled upon this frame recently :
https://aliexpress.com/store/product/20 ... 16600.html
Does anyone recognize this mould ? What do you think of it ?
Bluechip
by Bluechip
Seems overpriced for a fairly heavy no name frame but it looks great with that paintjob. Other than that it looks like almost any generic "aero" bike. Also limited sizes available.
chalkie
by chalkie
LeDuke wrote:
Sat May 12, 2018 7:43 pm
Can only agree. Replaced mine straight away.
wisdom
by wisdom
Can you send me a link please?
LeDuke
by LeDuke
Here’s the bottom:
Cane Creek 110-Series Stainless Steel Cartridge 1.5" https://www.amazon.com/dp/B009MI428W/re ... -AbMJF24SP
And one of these for the top. For some reason they only come in pairs. Give one to a friend?
Cane Creek 110-series stainless bearing (42mm), 1-1/8" Italian https://www.amazon.com/dp/B00AEUXZ4Y/re ... -AbYR812KT
romanmoser
by romanmoser
Saw a nice '' SL6 '' like on a french forum
Frame testing of the 1X chinese bike ( like 3T strada )
https://ae-cn.alicdn.com/s2zmPqJJMzIYNU ... 0%40hd.mp4
MON5TER
by MON5TER
Hexsense wrote:
Fri May 04, 2018 10:20 pm
Anyone found any more info on the Dengfu R10? I've had a good search and crickets!
Ticks boxes for me with tyre clearance (up to 32mm) for a commuter/ just for fun sportif bike.
romanmoser
by romanmoser
Hadn't see this one goes out
It looks great on paper
But I couldn't find more informations neither
