Hongfu FM-066/Chinese open mould frame thread
iwata74
by iwata74
Workswell WCB-R-095 arrived! More images are here: http://imgur.com/a/UWhtL
I feel the frame and the fork are noticeably more noodle than Giant TCR Adv 2009 (not riding feel, just I grabbed the front / rear end). TCR Adv is much lighter than WCB-R-095.
oldmac
by oldmac
preferthecar wrote:
oldmac wrote:I have just built my gravel bike, the frame was from Workswellbikes.
That's hawt! Nice work. Give us the details!
Frame and Fork/ Size / Year:
Workswellbikes WCB-C-112/size49/2016(The frame is 1154g and the fork is 419g)
Handlebars / Stem:
Easton EA70(40cm)/3T ARX PRO 90mm 17degree
Hub / Rim / Tire:
Chosen CX Hub(100×15 Thru Axle front and 142×12 Thru Axle rear )/Xiamen Disc Brake rim 38mm(510g)/ Panaracer CG CX
Crankset / Bottom Bracket:
Shimano Ultegra 6800 165mm/Shimano Ultegra BBR60 BSA
Saddle:
Specialized Toupe Ti rail
Pedals / Chain:
Shimano XT M8000/Shimano HG700
Shifters / Derailers:
Shimano Ultegra 6800 Shifters/Shimano Ultegra 6800 Deraileurs (Middle Cage Rear)
Cassette Sprocket:
Shimano Ultegra 6800 11-32T
Brakes:
TRP HYD ROAD Flat Mount(160mm disc front,140mm disc rear)
The 100×15 front Thru Axle is not the same as MTB, it's shorter. I bought a second hand RockShox Maxle Stealth Front Axle,then modified it and replaced the stock axle. It's much lighter! I am going to make an rear axle too. You can find more pictures at here:http://s131.photobucket.com/user/megatronhe/library/Gravel%20Bike?sort=3&page=1. I will keep on updating, thanks for wacthing.
silvalis
by silvalis
What did you do to the maxle? Just thread it further up the axle so lengths match?
Chapter 2 Tere
Scott Spark 720plus
joejack951
by joejack951
If that frame is like my Hongfu FM-079-F with 15mm front thru axle there is a Rock Shox Maxle Stealth made to fit (M15x1.5mm thread x 125mm long). Cost $35 or so.
oldmac
by oldmac
silvalis wrote:What did you do to the maxle? Just thread it further up the axle so lengths match?
This is the difference between two axles. I cut the Maxle to be the same lenth as the stock axle, then rethread it.
iwata74
by iwata74
Has anyone built WCB-R-095? I cannot find how can I mount junction box.
kidrob
by kidrob
ok, wow, this is sexy! How did the communication with Workswell go regarding the color, what did you ask them to do?
kidrob
by kidrob
Here is a great video of some guy reporting about the process and unboxing some Dengfu frame I thought is worth sharing: https://www.youtube.com/watch?v=XVrczXtTtrA
gzon
by gzon
iwata74 wrote:Workswell WCB-R-095 arrived! More images are here: http://imgur.com/a/UWhtL
Will be interesting to see how this frame works once your build is ready. Stiffness, weight and comfort are interesting evaluation points.
oldmac
by oldmac
I communicate with Workswell through Email, they send me a website with lots of color sample,I pick up which I want. If you want some logo on your bike,you need to send the digital logo to them.
kidrob
by kidrob
Sorry, beginner question and hopefully in the right thread: How do I find out/calculate stem length/degree?
I am about to order the AC066 from Ican (http://www.icanbikes.com/html/Competiti ... k_desc_tab), size 58...
kart17
by kart17
Looking to part out my WCB-R-081 and sell the frame size 54. The bike is comfortable but I will start doing triathlons so I'm going to be getting a TT bike as a result.
joejack951
by joejack951
kidrob wrote:Sorry, beginner question and hopefully in the right thread: How do I find out/calculate stem length/degree?
How did you decide on a size 58? Do you own a bike that fits you well and do you hope to duplicate that fit or change things up? Without a baseline for size, all we can do is guess. There is no one perfect bike 'fit' either. You could be happy with a range of stem lengths and angles on the same frame. If you are new to cycling, plan on experimenting with different stems to find the best one for you and your intended purpose (the latter of which can change from ride to ride). And keep in mind that handlebars affect reach as much as stem length. Don't ignore those measurements when considering how your new bike will fit.
kidrob
by kidrob
Hmm, ok, thanks for the quick reply!
Well, the old one is size 60 and a Canyon Ultimate AL, so kinda a different type of bike...
In the end I am struggling a bit atm as Ican just told me they cant offer me BSA and only BB86.
I am now in contact again with Hongfu ($100+ more expensive) but cant decide between the FM066 and the FM069 :roll:
joejack951
by joejack951
kidrob wrote:Hmm, ok, thanks for the quick reply!
Ignore the manufacturer's 'frame size.' Those are taken so many different ways and the measurement in general is meaningless to how the frame will fit. What you need to mostly consider is the horizontal and vertical distance from your saddle to the shift levers. There are many factors that play into the former measurement but in general, it is determined by the 'reach' of the frame plus your stem length/angle/orientation and handlebar reach dimension, and, of course, how you position your saddle on the seatpost. If you don't have the 'reach' dimension for the frames you are comparing you'll need to look at top tube length but adjust for different seat tube angles, if they don't match.
The latter (vertical) dimension is determined a similar number of factors including the 'stack' dimension of the frame, headset top cap height, any spacers you install, plus stem length/angle/orientation.
Needless to say, it's a bit complicated if you want an accurate picture. One of the best things you can do is to draw the frames in 2D and compare with various stems, spacers, and bars in that manner. I can assist you with that if needed. Or you can just look at the various dimensions, get something close enough, and adjust to suit. You'll likely be doing some of the latter regardless.
I can attest to the quality of the frames Hongfu produces. From what I've read, they tend to be more expensive but they also produce a cleaner frame, especially on the inside, which is important for internal cable routing. I had no issues (due to the frame/fork itself) running the internal cables on my FM079-F. The only slight issues I had were due to using compressionless brake housing, but that isn't Hongfu's fault.
