Just checked it out and it's minor differences in my size (52). Looks like it fits my needs perfectly.
Thanks for the tips guys.
All open mold frames are on the heavy side (850g+ for 56cm). Looks for ones with 27.2mm seatpost; option to run regular, non-integrated bars; BSA or PF30 BB shell; non-integrated seatpost clamp. These will allow to shed major grams using WW parts, which you'd have hard time with proprietary standards and full integration. Always ask manufacturer for fork/frame weight in your size, unpainted. It also helps to ask to pick the lightest from the batch.
I’m in the same boat. I’ve been looking at the Winspace SLC2.0. Not the lightest but I think you could put together a nice light build with the right components.nrjansen wrote:Hi there!
Need a new project. Any recommendations for a light frame to climb the mountains?
Thanks!
Hello,Jelger wrote: ↑Wed Apr 07, 2021 9:03 am
Yes I have finished the build 2 weeks ago. Due to the really shitty weather just did 1 test ride but so far I like it. It's light and very responsive. Accelerating is super easy and it feels quite stiff but yet comfortable.
The paint job is very nice (although it is a copy of the chapter 2 tere). And the geometry is a copy of the Tarmac SL6 (just like the velobuild vbr-086).
This looks ideal for a project I have in mind. Did you weigh the frame and bars ?nrjansen wrote: ↑Sun Mar 21, 2021 5:40 pmProject finished! Did a quick 25km test ride today and my first impression was absolutely great. Will update on my experience again when I've done some more rides. See also https://roadmeister.cc
What are compressors ?madspalme wrote: ↑Sun May 02, 2021 10:53 amI also got my VB-R-099 in March. Same as the grey one posted above
Its build up with Sram Red eTap 11 speed and Farsports Kaze 58 with DT Swiss EXP240 with 28mm Pro One
Pedals are look keo blade and saddle is S-works toupe pro
Color is chameleon green and it is beautiful. Details are not as exact as pro level bikes, but that is to be expected. Also the painting is not as anti scratch proof as more expensive bikes.
It weights 7,9kg including everything as far as i remember.
Have 1200k on i an it absolutely rips. Love it!
Only complaint i have is that their bottle cages scratches the hell out of my bottles but i can live with that.
One of my friends have the same and he got an issue with the steerer tube compresser threat, hence a new is on its way from China, so maybe be sure to get extra compressors for the seatpost and steerer tube when ordering.
Yoeleo R11?HolyDiver wrote: ↑Wed May 05, 2021 4:58 pmHello,
I'm looking for a carbon frameset for training\racing since there is nothing available in my contry right now and I want to change my aluminum one.
Looks like hongfu/dengfu is right choice for the budget, but I believe there should be another options available.
It would be nice if someone could recomend based on expirience good frames.
Main criateria:
- Rim brakes
- BB86 or threaded or something to fit 24mm spindle without extra washers, etc.
- Some sort of semi-aero geometry like SL7
Weight is not so relevant for me since I would save much vs aluminuim.
Thanks.
Saw it, but would like to stick with aluminium handlebars.Toybota wrote: ↑Wed May 05, 2021 5:01 pmYoeleo R11?HolyDiver wrote: ↑Wed May 05, 2021 4:58 pmHello,
Main criateria:
- Rim brakes
Thanks.
Little bit more than Dengfu but comes with a bar with free shipping I believe.
I was supposed to weight every single part but was so exited building it that I completely forgot about it. Total weight of my bike is just below 8k.Steve Curtis wrote: ↑Sat May 01, 2021 6:24 pmThis looks ideal for a project I have in mind. Did you weigh the frame and bars ?nrjansen wrote: ↑Sun Mar 21, 2021 5:40 pmProject finished! Did a quick 25km test ride today and my first impression was absolutely great. Will update on my experience again when I've done some more rides. See also https://roadmeister.cc
Thanks
