Hexsense
by Hexsense on Sun Mar 14, 2021 1:20 am
garbageman wrote: ↑Wed Mar 03, 2021 1:36 am
Are there any Chinese or open mold frames that maintain 58ish mm trail in the smaller sizes? I have been searching but usually the small sizes have very slack HTA with a low offset fork. I'd rather a normal HTA and deal with the toe overlap than ride something with high trail and slow handling.
Kinda found one. Trifox X16 do not maintain consistent trail value. However, it use 50mm fork offset across the whole size range. So, size 49 and 52 has close to ideal trail value. Meanwhile, larger sizes may become a bit twitchy.
https://trifoxbike.com/products/x16-spe ... 5145890895
Hambini just recently review Trifox X10 (different model, that one use 45mm fork offset). So I guess they aren't too 'unknown' ?
opticsflash
by opticsflash on Sun Mar 14, 2021 3:29 am
nrjansen wrote: ↑Wed Mar 10, 2021 11:24 am
opticsflash wrote: ↑Mon Mar 08, 2021 8:47 am
Just finished my Velobuild-r-099 build, not a weightweenie focused build. choose most common components and need to be comfortable to right.
Ultegra di2 8070 full set (really hard to find the 165 crank), farsports Kaze DT350 wheelset with hutchinson fusion5 performance tubeless setup. Fabric scoop flat saddle (heavy but really comfortable for me)
e.
Looking forwards seeing some images of your build.
few pics
nrjansen
MarcFaFo
tigradekat
by tigradekat on Sun Mar 14, 2021 10:57 am
opticsflash wrote: ↑Mon Feb 08, 2021 10:59 pm
do you have a rubber piece covering the seatpost and frame intersection? I'm not sure where can i buy such a piece. thanks
tigradekat wrote: ↑Fri Jul 10, 2020 7:51 am
ms6073 wrote: ↑Thu Jul 09, 2020 9:28 pm
tigradekat wrote: ↑Thu Jul 09, 2020 1:30 pm
This week I received my Workswell 268 disc frameset, having ordered it end FEB. Fit and finish are good to excellent. The build specs:
Awesome, just what I wanted to see. Curious if you have a profile picture from the side that shows the integrated bar, specifically the drop of the stem? Also, did Workswell provide any spacers to match the integrated handlebar stem profile and if so, how many and what height?
I just took a quick snap of the handle bars "en profil". There are three contoured spacers in addition to the base plate, 1x 5mm, 1x 10mm, 1x 20mm.
The rubber piece came with the frame set.
Edit: I now see I'm a bit late in my reply haha, haven't visited in a while. Water still gets in the downtube with the rubber collet, but it does look better.
Nice build you have, enjoy! I'm still very happy with mine.
tigradekat
by tigradekat on Sun Mar 14, 2021 11:29 am
tigradekat wrote: ↑Mon Sep 21, 2020 8:47 am
opticsflash wrote: ↑Mon Sep 21, 2020 7:59 am
tigradekat wrote: ↑Tue Sep 08, 2020 7:34 pm
slippy wrote: ↑Tue Sep 08, 2020 5:58 pm
What was the issue? Did they break or arrived broken?
The aluminum insert in the handlebar is separating from the carbon, despite the fact that I use a torque wrench @ 5nm. Workswell never made a fuss, and authorized a warranty replacement within 10 days of me reporting the issue
What also speaks for Workswell is that they want the broken part back to investigate the cause of the failure. Although the failure itself is annoying, so far the way Workswell is handling it is exemplary.
How's your bike overall, do u feel any flex when riding out of saddle and sprint?
Would be interesting to learn, considering buying the wcb-r-256, thanks
Overall the bike is a blast. It corners very confidently, and certainly the BB is a stiff as they come. The fork is not the most rigid in the world I think, as I can get the front disc to rub with out of saddle hard efforts. Not sure how common this is though as this is my first disc brake equipped road bike.
Other than that, this bike just fits me like a glove. I did a 72km ride yesterday, and about 25km was straight into a 4bft head wind, with absolutely zero shelter. I was in the drops all of the time with zero discomfort. It's fortunate I can still use the defective handlebar because Workswell are struggling to keep up with demand. My replacement handlebar is going to be available only in October, and my contact at Workswell told me that they might temporarily suspend consumer-direct sales early next year because they cannot keep up with production.
Oh and before I forget: the replacement handlebar arrived a few weeks ago. So though it took a long time, Workswell came trough in the end. Luckily it was in the off season.
nrjansen
nrjansen
by nrjansen on Sun Mar 21, 2021 9:02 pm
RDY wrote: ↑Sun Mar 21, 2021 8:57 pm
Out of interest, why do you tilt your saddle back? Colour looks good.
That's exactly the same I asked myself when sitting on it
