New BMC Aero frame TMR01
MC356
by MC356
Quick questions about all the other TMR owners here.
I have been thinking about rebuilding my wheels on my TMR (2011 Easton ec90 55mm) with new hubs, white industries . I was thinking maybe I should upgraded the rims too. Can the TMR frame fit 25mm wide rims?
Thanks!
BMC TMR01
Niner Air 9 RDO
mr4fox
by mr4fox
Yep. No problem.
My toroidal runs are 28mm wide at the widest point. I can’t teally fit a 28mm tyre on the rear though. I mean a tyre that actually measures 28mm wide on the rim (I have a 25mm clincher that measures 28mm so had to put it On The front for example). It physically fits on the rear but there’s so little clearance that small pebbles that get stuck to the tyre when the road is damp will scratch the frame.
MrDeia
by MrDeia
MrDeia
by MrDeia
I have a question/issue regarding the brake
outer cable running underneeth the crankaxle the TMR01
As i have installed a Rotor inPower crankset with it's 30mm spindle, the axle is not covered inside a plastic tube like with the original Ultegra crankset. This is causing the outer rearbrake cable housing to rub the axle.
The originsl Ultegra bracketbearing set is having this plastic tube between the 2 bearings to protect the axle from dirt and to protect the axle from getting rubber by the outer rear brake cable!
Does anyone know if there is a bearing kit for the Rotor set which is having a plastic tube between the 2 bracket bearings? Or is there anyone who had solved this differently?
mr4fox
by mr4fox
I ordered a ceramicspeed bpx B.B. a little while ago. Not the same I know, but they sent it with just a peice of flat plastic that you roll up and stick between the two bearing cups. Would something like that work?
