New BMC Aero frame TMR01
Looooove the look of these bikes!! I have a few Q's
Ive seen TMR01 frame set weights listed as: Frame 1140g
Fork 440g
Seatpost 187g
which gives a total of total of 1767g
Can anyone tell me if the frame and fork weights include the integrated brakes or not? (this is weightweenies after all
Does anyone know what the Maximum tyre width is that will fit on the TMR01 is? can a 28mm tyre fit on the rear for example?
Ive found a 2013 TMR01 frameset on sale. does anyone know of any significant differences between 2015/15 and the 2013 frames?
I'm trying to compare the TMR01 to the Felt AR1 for my new ride. love the look of the felt but haven't found any comparisons yet.
thanks in advance
Fork 440g
Seatpost 187g
thanks in advance
mr4fox wrote:Looooove the look of these bikes!! I have a few Q's
Fork 440g
Seatpost 187g
thanks in advance
The weight is without integrated brakes.
Maybe a 28 mm tyre will fit. In the photo the rear wheel is mounted with a 24 mm continental and its plenty room.
No diferences between 2013 and 2015 frameset only the paint.
Enviado desde mi iPhone utilizando Tapatalk
Fork 440g
Seatpost 187g
thanks in advance
From what I have found .....
.................. BMC TMR01 56......................Felt AR1 56
Frame..................1200.................................1100
Fork (uncut)...........440 (with brakes)...................330
Seat Post (uncut)....143 (no clamp).......................300
Totals..................1783 grams.........................1730 grams
So they are pretty close. My bike is at 7.3 Kg / 16 lbs and is not a real weight weenie build so it could ezaly go down. I will say I am impressed with the TMR01 in every way and it gets complements most every ride, if don't mind a bit of attention.
I'm not sure about 28mm tires I think it will depend on the brand. My 25mm Continental Gatorskins at a pretty close fit but they are said to be a tall tire. (see below) I could go wider for sure, so 28mm wide would not be an issue, but I'm not sure how tall they would be.
C64 My Sixty 4 SR EPS 12
Thanks for the help trilocus and KarlC. i was just trying to figure out roughly what a build would come to with all my parts. I had my GF01 down to 6.67kg. It seems that my GF01 frame set and seat post were only 90g lighter than the TMR. I had weight weenie brakes on the GF01 which might have saved a bit more weight relative to the TMR01.
Any idea what the TMR brakes weigh? i imagine theyre pretty light no? i hear them referred to as "mini V's" so i'm guessing (hoping) they're small and light.
Are you guys happy with the comfort for 4+hr rides? (which was the main reason i was thinking of running 27 or 28mm for base training).
KarlC, i think i'm in love with your bike!
mr4fox wrote:Thanks for the help trilocus and KarlC. i was just trying to figure out roughly what a build would come to with all my parts. I had my GF01 down to 6.67kg. It seems that my GF01 frame set and seat post were only 90g lighter than the TMR. I had weight weenie brakes on the GF01 which might have saved a bit more weight relative to the TMR01.
Here is a good shot of the front brakes, I don't know the weight ...... http://d4nuk0dd6nrma.cloudfront.net/wp- ... MR01-1.jpg
I have no issues with 4+hr rides and compared to my last bike Scott CR1 (it had the same wheels, tires and seat) the TMR01 rides much smoother. Of course a lot is based on your seat, tire size and PSI
Thx I hear that a lot, people really like the look of this frame in person. I need to get some updated photos, my bike is looking even better now.
mr4fox wrote:Awesome! Thanks again for tye help. The one I had found on sale just sold outbid my size...guess I'll have to keep looking
viewtopic.php?f=5&t=132988
Thanks for the tip KarlC. I ended up buying that one and i absolutely love it! 7.03kg atm but some more lightweight parts on the way. should be 6.9ish with 60mm tubs and 6.55kg with climbing wheels on... Btw, i think this bike is an awesome climbing bike. Sooooo stiff at the front end. zero flex when out of the saddle hammering it.
mr4fox wrote:Thanks for the tip KarlC. I ended up buying that one and i absolutely love it! 7.03kg atm but some more lightweight parts on the way. should be 6.9ish with 60mm tubs and 6.55kg with climbing wheels on... Btw, i think this bike is an awesome climbing bike. Sooooo stiff at the front end. zero flex when out of the saddle hammering it.
Thats great I'm always hoping for more BMC TMR01 builds, please start a thread on your bike in the below section so we can see what you are up to.....
viewforum.php?f=10
prebsy wrote:Has anyone replaced the seat clamp bolt with a hex bolt? I use saddles with cut outs so that would be a lot better IMHO. I'm not sure if this is the right application for a TI bolt...thoughts? experience?
Yes I did this right away as I have a seat with a cut out and it makes it so much ezer to make adjustments. Just got one from the local Home Depot
I also found a 2nd seat clamp on ebay that I plan to drill and grind on some day to lose some grams, at that time I will buy a TI bolt also.
