New Hollowgram
spud
by spud
yes, been using Spidering with SiSl for 6-7 months on 10 spd, works great.
njspanasonic
by njspanasonic
6+ months with Chorus 11 speed, Spidering 53/39 on Hollowgram Si Sl everything works perfectly !
Now, can anyone confirm the Stages Hollowgram Sl forged arm works with the 104mm spindle ? I stuck with the 104mm spindle when I switched to Spidering with no problems..
NiFTY
by NiFTY
I have a stages Si arm on a sisl crank with 104mm spindle. Works fine. The crank offset is the same from forged si to sisl arms. As the si is marketed to work with sisl2 arms i would say they must all have the same crank offset. Does this mean the q factor of the sisl2 is 5mm wider than sisl due to 5mm increase in spindle width?
mythical
by mythical
“I always find it amazing that a material can actually sell a product when it’s really the engineering that creates and dictates how well that material will behave or perform.” — Chuck Teixeira
stephen@fibre-lyte
by stephen@fibre-lyte
£800!! :shock:
I like the look of them, but……£800!!!! :roll:
jooo
by jooo
A bit sad to not see an MTB Spidering (yet)?
Pepsi
by Pepsi
Two months ago I have bought a Cannondale SuperSix EVO Hi-MOD Dura-Ace Di2 bike. After 3 weeks my HollowGram SiSL2 started to produce some strange noises. This started after ride in the rain. I took my bike back to the shop. The mechanic has cleaned the bottom bracket and he has installed some new grease. For 1 month it was okey. Now the problem is back (after i cleaned my bike). I called the shop and the mechanic told me that this normal and that he got an offcial response from Cannondale that this is a maintenance issue :shock: :idea: !
It is a little bit strange to clean the bottom bracket after every ride in rain!
Here is a video where you can hear this noises.
https://www.youtube.com/watch?v=V0BvFOS76ks
Does any of you have similar problem?
Nebby
by Nebby
Sounds like your standard BB30 creak; did they try the using locktite?
Pepsi
by Pepsi
I dont think so!
12x23
by 12x23
Anyone running 110mm 50/34 Spiderings with Campy 11sp? Hoping your experience is as positive as njspanasonic's with 53/39 ,,,
timbat
by timbat
Does anyone know who to mix and match SiSL2 and SL cranks ? I know the spindles changed when they went SiSL2. I must be possible as Stages users must tackle this problem.
phlip
by phlip
Pepsi wrote:I called the shop and the mechanic told me that this normal and that he got an offcial response from Cannondale that this is a maintenance issue :shock: :idea: !
Not just strange, unacceptable if you ask me. Did this mechanic offer to look at it once more, or did he dismiss the problem as "a maintenance issue". I would not accept a creaking BB on a CAAD8 with Sora. Your bicycle cost as much as a new car.
Pepsi
by Pepsi
They send my bike back to factory. Now is ok.
