PinaRene
by PinaRene
Dura Ace 9170 Di2 front and rear derailleur
Dura Ace 9200 crankset and 12 speed chain
Dura Ace 9270 disc calipers
Waiting on the Stages Dura Ace 9200
C36
by C36
A pair of the out of production Comète Ultimate with carbon shell.
249g in 42 2/3 (here weighted with 83g cleats)
The quality of the entire package is quite something and if they fit you they are amazing. Fantastic ankle freedom and remain incredibly stable during pedal stroke.
When walking I had heel moving a lot but while pedalling nothing.
With 83g cleats installed.
facelessfools
by facelessfools
Finally returned home to all of these, plus there is more on the way...
2014 felt f1
EE brakes
Hollowgram with stages
Garbaruk 52t melon
Ride now tubes
Extralite headset
Darimo integrated bars
Darimo seatpost
Building a Ti 29er so got the following
Bontrager kovee pro tlr
Dt swiss fork
Dt swiss shock
Wolftooth headset
Wolftooth clamp
Got some tools
Parktool stand
Integrated cable kit
Fork saw guide
Bearing press
Hydraulic hose kit
Lyenze floor pump
Shock pump
New scale
Hope bleed kit
Considering getting different wheels since these kovees aren't exactly light, sitting about 2000g for the pair w/ rotors Image
Sent from my Pixel 6 using Tapatalk
MichaelK
by MichaelK
Is that the Cannondale aero spider on the Hollowgrams?
recoilfx
by recoilfx
It wasn't today or yesterday, but about a week ago I got a Chapter2 Koko frameset and transferred everything from my old faithful Tere. It rides like a dream and as a short rider (5'7", 64kg), for the first time I can finally feel vertical compliance from a road bike frame. I used to run 65psi on the rear wheel, now I can run at 70psi and it's still more comfortable than the Tere.
The seatpost does look kind of off, but it's functional and the look grew on me. In any case, I am making a seatpost sleeve that will function/look like the new Canyon Aeroad. Deep section on top and little D shape on the bottom, with integrated Garmin Varia mount.
facelessfools
by facelessfools
MichaelK wrote:Is that the Cannondale aero spider on the Hollowgrams?
It is in fact the aero spider on there. It was a toss up between running a digrit carbon ring on the aero spider or the garburak single ring.
jurez
by jurez
9150 levers and some new stuff in the mail also coming in the next few days.
Santa came early? :)
ms6073
by ms6073
New kit from Panache, except they left out one pair of socks.
- Michael
"Solving problems you didn't know you had in ways you probably won't understand"
ultimobici
by ultimobici
Got a little misty eyed and bought some cleats & shoes to use my SPD-R pedalsImage
facelessfools
by facelessfools
Continental cross king
Jagwire cables
Jagwire rotors
New ultimate post and bars
Syntace flatforce
Kmc chain
Esi grips
Hope tech e4
Dt swiss locking lever axle cups
Wolftooth bar ends Image
Beancouter
by Beancouter
Not bad for a 30mm tyre (tubes). Image
ND4SPD
by ND4SPD
Let there be light
Not't really weight weenie, but the amount of light is awesome. I mostly use it in smart mode.
GIANT RECON HL 1800
Smart Mode light sensor monitors ambient light to adjust light output accordingly
The Recon 1800 can pair with ANT+ compatible computers to view battery information on the computer screen.*
ANSI certified lumens and run time
Focused optics with side light design for over 270-degrees of visibility
Heat-dissipating CNC-machined aluminum casing
Power status indicator alerts remaining run-time before powering off
Includes adjustable GoPro mount
*Giant recommends operating the HL1800 in manual mode when using Garmin computers.
Weight: 190g without mount
Colors: Black
Output: 1800 lumens
Runtime: High (1800LM) 1.5hrs, Middle 3.5hrs (900LM), Low 7hrs (450LM), Smart Mode Day (100LM>450LM) 40hrs; Smart Mode Night (900LM) 3.5hrs, Flash (100LM) 65hrs
Battery: Li-Ion polymer battery (6400mAh)
Water resistance: IPX6
Certifications: ANSI-Standard FL-1
https://www.giant-bicycles.com/us/giant-recon-hl-1800
Regarding Garmin:
https://support.garmin.com/en-GB/?faq=q ... jDph6tA877
Read it like this- buy our lights.
*How I paired the Recon HL 1800 with my Garmin
You need to pair the light first like you would any other sensor, which creates a 'light network', and then configure a data page or field if you want one on your chosen profile. You don't need one though – you can see a five-point battery indicator on the Garmin's sub menu – and in the light network settings you can select how it powers on (either by turning your Garmin on or by starting a ride) and what mode you want to run it in.
In essence, you lose the ability to control the light manually from its power button, so I chose to run it in 'individual' mode, activating when I started a ride and switching off when I ended it. This gave me control over the brightness setting when the head unit was on.
With its published advice, Garmin might simply be covering itself in case any faults were to develop with either device, but it is indicative that the link might not be bulletproof or fully approved by Garmin's third party policy. To be safe, given that my personal 520 Plus was on the line, I chose to remove the connection once I had established that it worked, given that I consider it more of a 'nice to have' than an essential function.
https://road.cc/content/review/giant-re ... 800-279965
poulhansen
by poulhansen
For my 1985 La Vie Claire TT bike build
[/img]https://cdn.shopify.com/s/files/1/1380/ ... 1622620515[/img]
Cannondale six13, 2004, 5.59kg
