rukomasa
by rukomasa
it measures both leg power as you may know. it is not a single leg in that context. if you dont like the word "side" then please read it as leg. and btw powerbox does not provide even estimated LR balance unless you paid more.
robbosmans
by robbosmans
rukomasa wrote:Imageit measures both leg power as you may know. it is not a single leg in that context. if you dont like the word "side" then please read it as leg. and btw powerbox does not provide even estimated LR balance unless you paid more.
Ah I understand now
markdjr
by markdjr
For those with the Hopp quarq cap, I have had good luck with a good sized piece of aluminum foil in there.
Ben689908
by Ben689908
An Ambrosio Shimano spline / Campagnolo 10sp spacing cassette so I can:
1. run my Shimano hub touring wheels on my winter bike over the next few months; or
2. On those dry days over the next few months, run my Shimano hub 50mm carbon wheels.
The wheels on my winter bike are due a hub service so I need to buy bearings (Fulcrum Quattro 17mm axle) if anyone knows a good stockist.
Ben
Bikes: Donhou DSS4 Custom | Condor Italia RC | Gios Megalite | Dolan Preffisio | Giant Bowery '76
Instagram: https://www.instagram.com/ben_h_ppcc/
Flickr: https://www.flickr.com/photos/143173475@N05/
LeMomo
by LeMomo
New shoes to try
ImageEmpire! by Matt Cotterill, on Flickr
FIJIGabe
by FIJIGabe
Snagged a set of Bontrager Speed Stop Pro's off Facebook, today for $115. 33g heavier than the eeBrakes G4 Direct Mount brakes, but a whole lot cheaper! Should get my Emonda to around 6.4kg, even.
Kayrehn
by Kayrehn
850g wheels for wife's build, all thanks to @UpFromOne for the extralite hubs that started the build. Berd spokes and 30mm rims from my friend's China source. Might be spoiling her (as a total newbie) without her even knowing how good these are though Image Image
dolophonic
by dolophonic
man that is light weight .. clincher ? :beerchug:
Mimmo89
by Mimmo89
Kayrehn wrote:850g wheels for wife's build, all thanks to @UpFromOne for the extralite hubs that started the build. Berd spokes and 30mm rims from my friend's China source. Might be spoiling her (as a total newbie) without her even knowing how good these are though Image Image
Will you take me as your husband? Image
Sent from my CLT-L09 using Tapatalk
ms6073
by ms6073
DHL will be delivering a Colnago C64 disc next week, having taken only 34-days since placing the order.
- Michael
velomane
by velomane
ms6073 wrote:
Fri Oct 30, 2020 9:49 pm
What an awesome paintjob!
fogman
by fogman
Very unique paint job. What do you have planned for your C64 build?
It's all downhill from here, except for the uphills.
ms6073
by ms6073
Nothiing special as I will just be swapping parts (DA9150/9170, FC-R9100P, Nox Composites disc wheelset. Handlebars are the real quandary as Icurrenty ride and really like the flared Enve SES Aero handlebars but want to eliminate the junction A under the stem, but am reluctant to cut the bar end off in order to use the bar end junction.
- Michael
KyleH
by KyleH
I think I found the last Tacx Neo 2T in our area and finally picked one up. Actually eager to get back to training again.
Kayrehn
by Kayrehn
dolophonic wrote:man that is light weight .. clincher ? :beerchug:
Always tubular for me ha. I can't be using tubulars then having to bring extra tubes and etc just for her Image
