My new Extralite CH-01.
Interesting that it weighs much heavier than advertised. Doesn't seem characteristic of Extralite. They're claiming 14.8g but we're seeing real-world weights of 20+g, which is a shame considering how easy it is to obtain computer mounts that are sub 20g.WannabeWeenie wrote:My new Extralite CH-01.
^ maybe they are not counting the stem interface brackets... because those would be there regardless if you had a outfront mount or not.
2024 BMC TeamMachine R
2018 BMC TImeMachine Road
2002 Moots Compact-SL
2023 Pivot E-Vault
2023 Pivot E-Vault
This page claims 15g weight difference:
I wonder if the mount is sturdy enough to hang a light from it.CH-01 adds only 14.8g to the total assembly and does not need any additional part.
Mine was 21.0g on the nose.
It's very sturdy.
95.9g total with a 110mm HyperStem.
It's very sturdy.
IG: RhinosWorkshop
IG: RhinosWorkshop
A PYC SP1101, but black. It weights the same.
Sure, I bought it here. I also put my Ellipse on too a couple of days ago, photos will follow.
Many thanks.
Sent from my SM-G960F using Tapatalk
Simply insane!!! Very nicely done!!KCookie wrote:Darimo UD Matte 40cm, 3 pre drilled holes.
Very happy with the weight. 136.6g.
The Herd
viewtopic.php?f=10&t=149524
That's likely what's happening. @ryanw or wannabeweenie: do you have handy the weight of the 2 stem brackets?spdntrxi wrote:^ maybe they are not counting the stem interface brackets... because those would be there regardless if you had a outfront mount or not.
Unfortunately not. They can preattached and I didn't bother unscrewing them.
IG: RhinosWorkshop
IG: RhinosWorkshop
