Indeed, it requires a bit of set up, then largely offset by how quick and accurate each measures are.flying wrote:Yes but as these were designed for stationary objects/building etc you need to replicate a perfect vertical position of your movable bike each time
- MrCurrieinahurry
- Moderator
Basso Diamante super record EPS 12
BMC slr01 ultegra Di2
2nd set of Zipp 303S , had one pair for the BMC URS Gravelbike and now also one pair for the BMC SLR01.
A pair of Conti 5000 S TR 28 mm tyres. I don't need them right now, but as the availability has not been very good, purchased them for later.
I was actually surprised that all sizes were available in a local shop and the price was cheaper than in the German shops I usually use.
Continuing my adventures in wider tyres, today a pair of Schwalbe Pro Ones in the new and hard to find 34mm width. They are rather grandly (over)packaged with a dark outer box and an orange inner box. I weighed one of them at 363g. Looking forward to finding out what a 34mm Pro One rides like and whether I'll retain road speed while also being able to tackle dry light gravel without worry.
cycling / nature / music
All 5 bolts on those calipers can be replaced with ti.
The two main bolts and the cable bolt are M6, the actuator pivot bolt is usually M4, and the pad retainer bolt is std. shimano.
I've gotten these calipers down to 115g. w/o pads.
Then try titanium-backed pads.
Zipp 404 Firecrest DB and a pair of Schwalbe Pro One Tle 25 mm, 5 pair of La Passione socks and some spare BMC decals ( original ) for the bike.
Cannondale Super Six HiMod 2017 6.7 kg
Cannondale six13, 2004, 5.50kg
Focus Izalco Max, 2023 4.418 kg
- robbosmans
- Moderator
- Contact:
