KCookie
by KCookie on Sun Jun 30, 2019 10:26 am
Squashednuts wrote:KCookie wrote: ↑Sun Jun 30, 2019 10:06 am
Lightweight stem awaiting my collection for a future build.
Sent from my SM-G960F using Tapatalk
Hey @kcookie
What are you planning?
Cheers
I'm waiting on a 2018 lightweight Urgestalt frame so all parts will be swapped over from my Urgestalt now, plus a Darimo post and clamp will be added. Hopefully be under 4.8kg, atm 4.88kg.
This stem will go on the old frame which needs repairing and then I'm thinking chameleon paint job. All DA DI2 parts with PM, EEs and my Obermayers. Just want something reliable and not so WW. Still should be about 5.6kg.
dgasmd
by dgasmd on Sun Jun 30, 2019 4:18 pm
Ouch! What happened to the old frame? Did I miss a thread or crash?
KCookie
by KCookie on Sun Jun 30, 2019 10:09 pm
Luckily not mate, just some damage from the chain dropping. Has worn quite thin and then thought why not give it a make over.
nismosr
by nismosr on Mon Jul 01, 2019 5:51 pm
Seedster wrote: ↑Sun Jun 30, 2019 3:18 am
Super Record 12 speed EPS groupset
RA the cheapest to get them.?
2020 Colnago C64 Mapei-SR12 EPS-WTO 60
2021 Basso Diamante SV-SR12 Disc EPS-WTO 60
2023 Colnago G3X-SRAM AXS Force-Levante
madik
by madik on Mon Jul 01, 2019 8:44 pm
BB86 Hambini Bottom bracker for 24mm axle. Super expensive Silver racing edition. The standard one wasnt in stock
Functionality > Performance > Weight
Seedster
by Seedster on Tue Jul 02, 2019 11:40 pm
nismosr wrote:Seedster wrote: ↑Sun Jun 30, 2019 3:18 am
Not the cheapest, but competitive and actually have it in stock. It’s new so I tempered my expectations about discounts
Many of the online places take your money and must wait for a distributer to dropship. I shop with them often, so I preordered it and got a fair price.
addictR1
by addictR1 on Wed Jul 03, 2019 7:36 am
nickf wrote:Weight was as advertised! Loops are interesting. Seems solid enough. Seatpost biner size was jam on. Tightened down nicely, no slippage or twisting. A full test ride will have to wait till after vacation.
Looking forward to the review. I’m skeptical about holding onto the saddle using those two strings. Do they have a weight limit? I’m about 152lbs so should be ok.. just worried about slippage since Cali Bay Area roads are crappy
Klaster_1
by Klaster_1 on Wed Jul 03, 2019 7:44 am
addictR1 wrote: ↑Wed Jul 03, 2019 7:36 am
One of T1s used to unwind with older T-clamps, but thread lock solved that. With loops, this happened only once, even though I tightened rear screw to 3nm. I think this might be caused by tension loss in front, I had to re-tighten the setup a couple of times.
dereksmalls
by dereksmalls on Thu Jul 04, 2019 9:48 am
I’ve had no problems with mine yet. I’m 69kg and the roads around here are pretty rough. Haven’t had to retighten the cables yet after a few weeks of riding. Cables were tightened just under 3Nm
