General Cycling News Chat. No off-topic chat please
Johnny Rad
by Johnny Rad
OUT with the prev-gen, non-Icon Kask Protone (sz L) and Kask Valegro (sz L)... and IN with the Lazer Z1 Kineticore (sz M).
The two Kasks in sz L were big on me and required tightening them almost all the way down, but their sz M was too small. I was pleasantly surprised to find that my giant melon fits Lazer's sz M. Keep this size change in mind when looking at the 30-50g savings. :smartass:
The Smith Trace (?) also fit nicely, but was noticeably heavier.
Miller
by Miller
C36
by C36
Thanks to a fellow WW member from NZ I finally got my hands on a pair of winter booties for the Mavic Comete carbon shoes that I searched for more than 18 months (and totally gave up… so many thanks to him!)
I knew they existed but production stopped years and years ago and completely sold out everywhere (even with Mavic help contactint the last shop who ordered some...).
The fit is surprisingly "the same" than the summer booties and probably bring more water resistance and windproof than massive thermal insulation to replace the shoes I use for negative temperatures but for 4-10 degrees or rain that should work!
nunokas
by nunokas
159gr of ring jewelry.
They're getting scarce in the wild :)
JMeinholdt
by JMeinholdt
Got some fat boi's for day to day riding.
Basso Palta II - SRAM Force AXS 2x - Road/Gravel/Commute
Wilier Cento10AIR - retired
Wilier Sestiere - Shimano Tiagra - Collecting dust
YouTube link: https://www.youtube.com/@JMCyclingVideos
Akio0911
by Akio0911
Thm passoni clavicula se power meter crankset and titanium bolts to match gold themeImage
我從使用 Tapatalk 的 Pixel 7 Pro 發送
mdeth1313
by mdeth1313
Trying out 36 cm bars.
Speedplay is the devil!
charirider
by charirider
Bought Magped Road 2.
Actually very nice! I pulled up very hard but couldn't disengage them, but simple up-slide to the side and they disengage nicely. Feel much more safe that on time xpresso 7 (I have knee injury from mountaineering so couldn't twist right leg outwards too much).
Road: 2018 Cannondale SuperSix EVO gen2 rim size 56 (raw stripped) 6.72kg
CX: 2014 Bridgestone Anchor CX6 Equipe 105 rim size 55 8.65kg
C36
by C36
Never been so happy to have to replace a BB!
That is the ceramtech version (not the coated one), was more looking for the lifetime warranty than the ceramic balls.
The Mech Eng in me is bizarrely happy to finally have bearings mounted as they should, with perfect geometry Image
Discovered this piece by pure luck browsing through Wera catalogue. 1 bit, 4 sizes, perfect to carry on the bike.
jayjay
by jayjay
C36 wrote:
Fri Jun 07, 2024 5:15 pm
What do you use as a handle?
C36
by C36
jayjay wrote: What do you use as a handle?
Since seatpost, saddle and bars need 4Nm I use the topeak with the torque bit (works also without).
I could also use the wera tire levers… just realised they sell the kit with also the torx one
Ritsuke
by Ritsuke
C36 wrote:
Fri Jun 07, 2024 8:45 pm
Saw this and immediately ordered the kit. Brilliant piece!
OtterSpace
by OtterSpace
Interesting timing I just got a wera tool haul myself and used the multibits previously. The multibits are good but the plastic levers are only rated to 10Nm and I had two staked destructively fail by camming out the plastic while removing a rear through axle that was previously attached at 10Nm which left me stranded that ride until I called home. Therefore, I'd only trust the pastic levers to 5Nm each. I moved to day saver essential 8 as that has no chance of pastic failure but a good holder would fix my issues with the wera.
Here is my recent tool haul to better fully support my two CDI torque wrenches that I've had for many years:
Still waiting on some vessel JIS bits to fill out the set but close enough. With many years of working on my bikes I've found that colored, or labeled tools are my top priority for home use. I'll likely add more colored heatshrink over the longer bits for easier color identification.
Wera 9720 Foam insert 8000 A Zyklop 1/4” ratchet set 1, 37 pieces
Wera 8784 A1 Zyklop bit adaptor, 1/4”, 1/4” x 37 mm
Wera 781 B 3/8” Connection parts, 781 B/A x 1/4 x 27 mm x 3/8”
Abbey Bike Tools LL Chain Wear Tool
Abbey Bike Tools 4-Way Multi-tool with Interchangeable bits
Abbey Bike Tools Bit Holder 2x
Wera Screwdriver Bit Hex-Plus 1/4" Hex 840/4 Ni Bits:
  • 4 x 89mm
  • 5 x 89mm
  • 6 x 89mm
  • PH1 x 89mm (placeholder: not needed but cheap enough)
  • T20 x 89 mm
  • T25 x 89 mm
Vessel JIS
  • #P00 x 1-15/16" (49mm)
  • #P0 x 1-15/16" (49mm)
  • #P1 x 1-15/16" (49mm)
  • #P0 x 25mm (placeholder: not needed but already had)
UpFromOne
by UpFromOne
Extralite SCR-058 just arrived, size small, mech routing, 545g bare frame with dropouts.
nickf
by nickf
UpFromOne wrote:
Thu Aug 08, 2024 9:50 pm
Will we see a build in the gallery? That frame has been tempting me since they released it.
