Interesting gearing stats from my century yesterday
My biggest surprise was that I spent over an hour on the 10T cog that got so much criticism.
This ride was with a group so there was a lot of drafting especially on the descents.
Ride stats for reference:
Data from axs.sram.com:
- robbosmans
- Moderator
- Contact:
What was your cadence? You spend a lot of time in the small ring.
I would've needed higher uncomfortable cadence. It was my descending gear not sprinting gear.spdntrxi wrote:you only did 70w in the 10t on average.. you could have done that in any gear. IE you didn't need it
Sent from my Pixel 7 Pro using Tapatalk
- robbosmans
- Moderator
- Contact:
Ah only looked at the last picture, but yeah as I expected lower cadence and small chainrings lead to a lot of time in the 10t
Pretty much the only time I’m pedaling in 50x10 on a descent is in a downhill sprint.
Berkeley Hills P12 state championship RR (very hilly) where I got dropped at 75/100mi
Snelling P12 RR on rolling terrain. Got in a late 3-man break at 75/92mi and stuck it.
Of course each ride is different, but if this is representative of a typical ride for you I would consider a 50-37, so that - regardless of the 10T - you spend more time in the middle of the cassette.
This is more of a typical ride for me.robeambro wrote:Of course each ride is different, but if this is representative of a typical ride for you I would consider a 50-37, so that - regardless of the 10T - you spend more time in the middle of the cassette.
The guy spends most of the ride in cogs 5-7, the very definition of the middle of the cassette. Time in 10t not a concern if on steep descent.
Giant Propel Advanced SL Red Etap 11s Easton EC90 wheels CeramicSpeed BB Zipp SL70 bars 6.5kg
Vitus ZX1 CRS Campy Chorus 12s Bora WTO 45 disk brake wheels Zipp SL70 bars 7.5kg
SL8 build with Craft CS5060 Wheels in progress
The above sawtooth gear selection seems so random to me. Typically my time in gears has a bell curve or at least some semblance of a pattern.
In what world is this "most of the ride in cogs 5-7"? There's around 1h 20m between cogs 5-7 in a nearly 6h ride. That said, they clarified that the ride posted wasn't representative of their usual riding, so it doesn't matter really.Nickldn wrote: ↑Tue May 23, 2023 4:16 pmThe guy spends most of the ride in cogs 5-7, the very definition of the middle of the cassette. Time in 10t not a concern if on steep descent.
