Question regarding brake bleeding
Hello everyone, I'm looking to change to narrower handlebars(42cm -> 38cm) and I would like to know if it's possible to change the handlebars without having to do a brake bleed. For context, I will be performing the handlebar swap on the newest generation Ultegra di2. I'm quite new to integrated cables so I'm sorry if the following is just downright stupid.
I don't think it will be necessary to shorten the brake cable. And so if I don't touch the pin I should be fine to just get the cables out and reroute them through the new handlebar?
martin752 wrote: ↑Fri Oct 14, 2022 4:43 pmHello everyone, I'm looking to change to narrower handlebars(42cm -> 38cm) and I would like to know if it's possible to change the handlebars without having to do a brake bleed. For context, I will be performing the handlebar swap on the newest generation Ultegra di2. I'm quite new to integrated cables so I'm sorry if the following is just downright stupid.
If your current bleed is immaculate, you MIGHT get away with it. Otherwise prepare to bleed your brakes.
Internal or external routing of the cables on the bars? If it's all external, you should be able to get the shifters off/on without disconnecting the hoses. Just becasue the bars are narrower doesn't mean the hoses need to be shortened, especially for 2cm per side.
I'm okay with bleeding my brakes, have done it on my other bikes. The reason I'm asking is because it will be around 3 weeks before I fly back home and have access to my bleedkit but since I would like to try out the new handlebars I wanted to know if it would be okay. I think I'll give it a try and if I mess things up then it will probably end up being a walk of shame to some local bike shop.TobinHatesYou wrote: ↑Fri Oct 14, 2022 5:16 pmmartin752 wrote: ↑Fri Oct 14, 2022 4:43 pmHello everyone, I'm looking to change to narrower handlebars(42cm -> 38cm) and I would like to know if it's possible to change the handlebars without having to do a brake bleed. For context, I will be performing the handlebar swap on the newest generation Ultegra di2. I'm quite new to integrated cables so I'm sorry if the following is just downright stupid.
All internal. Definitely going to need to disconnect the hoses.jfranci3 wrote: ↑Fri Oct 14, 2022 5:18 pmInternal or external routing of the cables on the bars? If it's all external, you should be able to get the shifters off/on without disconnecting the hoses. Just becasue the bars are narrower doesn't mean the hoses need to be shortened, especially for 2cm per side.
Do the connectors/nuts etc fit through the ports on the bars?
Internal hose routing to other handlebars require
1) remove olives
2) route hoses through new handlebars
3) install olives
4) connect hoods
- if you are lucky and did not drip and brake fluid out of hoses while getting air in, you may reconnect without need to bleed
- you also have to be lucky to have handlebars with similar reach or enough hose length. Last week I went from 40cm width / 70mm reach handlebars to 38cm width / 77mm reach handlebars and realized that my front hose is too short. That prolonged my process by one additional online order.
1) remove olives
3) install olives
4) connect hoods
SW SL8 RTP 56cm @ 9270 / CLX II / CS OSPW / CEMA BB
S Epic 8 L @ XX T-Type / Berg Ratheberg 30 / Quarq / Fox Transfer SL 100mm / 3p
