Hi there,
Can you help me please to pick up the correct size. Don't have an ability to visit Rapha store in person and try on both sizes in the nearest time. Not sure which one to go with: "S" or "M"? Which one would you recommend me to order?
I'm 180 cm. 75 kg.
Waist: 83 cm.
Hips: 94-95 cm.
I have never had Rapha bibs in the past, but i own a Rapha Pro Team Training jersey in "M" size, and it sits perfectly("S" was too small).
Rapha Pro Team Bib Shorts II - Regular: "S" or "M"?
At the moment you should be in a medium unless you plan to lose weight, then go with small.
Years ago I had a pair of their Rapha longer bibs in size M and Im both shorter and slimmer than you and I think you should actually be between M and L.
The long bibs weren't all that long and Id guess the regular ones are too small for person of your height.
