TI frame repair
Got a nasty HT/ST crack on my old Van Nichols TI frame...as a consequence of an "open and frank exchange of opinions" with a moving car.
Thoughts on getting it rewelded, or is the frame toast?
Sent from my M2103K19G using Tapatalk
"I saw you with elephants hosing down some dwarves on black and white TV" - Ode to Anthony H Wilson
- MrCurrieinahurry
- Moderator
Damn man are you ok?
Basso Diamante super record EPS 12
BMC slr01 ultegra Di2
All good. Still trying to work out how I broke off and shattered his wing mirror with my fist (on the brifter) and only had a tiny cut on my hand!MrCurrieinahurry wrote:Damn man are you ok?
I took a early 80's Camaro Berlinetta door almost all the way off with my middle finger. Yeah it was shattered but the door and my finger looked similar.
2024 BMC TeamMachine R
2018 BMC TImeMachine Road
2002 Moots Compact-SL
2023 Pivot E-Vault
2023 Pivot E-Vault
email.... info@ticycles.com
- Factor Ostro VAM Disc
- Factor LS Disc
- Specialized Aethos Disc
- Sturdy Ti Allroad Disc
- Guru Praemio R Disc
- Factor LS Disc
I spoke to David Levy. They converted my rim brake Guru to flat mount disc and put new chain stays to make room for 38mm wide tires.
- Factor LS Disc
- Factor LS Disc
