Sportful Roubaix Thermal Overshoes/Booties
Hi all, Any one used of these? there seems to be very little reviews available. Merlin cycle claims they are good to minus 5 degrees C, but they are also prone to misplacing item description. Even sportful themselves dont claim minus 5. If you have come across these, do you tink they can comfortably used around zero degrees C? also is csealing the shoes vent at bottom a must? Thanks.
Some say pour 10ml water out of your bottle to save that last bit of the weight. Sorry, i go one step further, i tend to the rider off my bikes.
n+1...14 last time i checked, but i lost count
I don't know about the Sportful booties but if you want warm and want to keep water out, check out Spatz Wear booties. You won't regret it.
