Best Floor Pump for under $100
lol fixedMarin wrote: ↑Tue Mar 23, 2021 3:59 pm$100 sounds expensive?
https://www.urbandictionary.com/define.php?term=floork
2020 Colnago C64 Mapei-SR12 EPS-WTO 60
2021 Basso Diamante SV-SR12 Disc EPS-WTO 60
2023 Colnago G3X-SRAM AXS Force-Levante
My LEZYNE CNC Drive has been great.
I can buy a 3 gallon aircompressor at https://www.harborfreight.com/3-gallon- ... 57567.html for 59 dollars.
You just need to find a inflator, but you could use a shrader value inflator, with an adaptor to presta. Total for that all should be way less than 100.00
whats a good psi compressor for seating tubeless tire ?vinny wrote: ↑Wed Mar 24, 2021 3:15 amI can buy a 3 gallon aircompressor at https://www.harborfreight.com/3-gallon- ... 57567.html for 59 dollars.
I have an 8 gallon compressor and a schrader/presta adapter. I always use my floor pump instead because of the hassle of the compressor. I only use the compressor for seating tubeless tires.vinny wrote: ↑Wed Mar 24, 2021 3:15 amI can buy a 3 gallon aircompressor at https://www.harborfreight.com/3-gallon- ... 57567.html for 59 dollars.
With that said, if I had the Park INF-2 inflator for my compressor, I'd use it a lot more. But that's $135 by itself.
Wilier Cento10AIR - SRAM Force AXS - Road/race
3T Exploro - SRAM Rival AXS XPLR - Gravel
Wilier Sestiere - Shimano Tiagra - Commuter
YouTube link: https://www.youtube.com/@JMCyclingVideos
have you check Arundel one about $60JMeinholdt wrote: ↑Wed Mar 24, 2021 5:02 pmI have an 8 gallon compressor and a schrader/presta adapter. I always use my floor pump instead because of the hassle of the compressor. I only use the compressor for seating tubeless tires.vinny wrote: ↑Wed Mar 24, 2021 3:15 amI can buy a 3 gallon aircompressor at https://www.harborfreight.com/3-gallon- ... 57567.html for 59 dollars.
I had not seen that. Not sure I like the fixed pump head. But maybe it would work.
