Agree new bar/stem but I have an R5 and it doesn't seem to have the same shaped head tube from those images. However, I hope you are right and I am wrong as I may be able to upgrade mine
2021 PRO equipment thread
I know, I already said I think it's new too...I guess the attempt at friendly humour didn't come across.
Some good pics of the Cervelo on cycling tips. Best Cervelo paintjob in a long time in my opinion. Assume that is the "camoflage" job and it will be back to the less interesting ones for production models:
https://cyclingtips.com/2021/04/primoz- ... -wallonne/
Cervelo R3 - 5.4kg viewtopic.php?f=10&t=142420
To be fair after hovering between average and awful for a long time Cervelo have finally designed and produced some genuinely excellent paint schemes over the last year. The various metallic and chameleon schemes are proper quality work.Rudi wrote: ↑Fri Apr 23, 2021 1:20 pmSome good pics of the Cervelo on cycling tips. Best Cervelo paintjob in a long time in my opinion. Assume that is the "camoflage" job and it will be back to the less interesting ones for production models:
Also they did produce a good run of frames of the current R5 with the camo scheme used for that prelaunch classics season so you could be in luck.
Finally a proper WC bike-white- for Julian
Was thinking that R5 paint job picks up the honeycomb pattern on the kits.
Very pretty rainbow Tarmacs.
- robbosmans
- Moderator
- Contact:
Rohan Dennis is using an Aerocoach front wheel or something similar by the looks of it, not the usual princeton
- Dan Gerous
Rohan Dennis & Geriant Thomas both on that front wheel while Riche Porte on the Princetonrobbosmans wrote: ↑Tue Apr 27, 2021 3:23 pmRohan Dennis is using an Aerocoach front wheel or something similar by the looks of it, not the usual princeton
Dan Gerous wrote: ↑Tue Apr 27, 2021 3:27 pmA better shot of Cannondale's upcoming TT bike that was spotted earlier this spring.
Looks like a SystemSix on roids...but I guess that's no surprise really.
Bahrain Victorious has announced, that from tommorow May 1st, they will use kit made by Ale. They used Nalini till Today.
Seems strange and I do not remember team changing kit supplier mid season and mid stage race
