2021 PRO thread
bikewithnoname
by bikewithnoname
At least Pog used the inner ring today. Still looked like he was out for a Sunday bimble
Time cut looks tight
Mocs123
by Mocs123
HammerTime2 wrote:
Wed Jul 14, 2021 3:19 pm
Pog on rim!!
Not to get into a rim vs disc debate (I have one of each) but assuming both bikes are 6.8kg what is the advantage of rim brakes? I've been under the assumption that Ineos uses them because the Dogma disc version is well over 6.8kg.
Alfus
by Alfus
Mocs123 wrote:
Wed Jul 14, 2021 4:57 pm
Pog on rim!!
Quick wheel change, less noisy, not really complicate descend today, no rain...
Dan Gerous
by Dan Gerous
Maybe the Colnagos with disc brakes are not as heavy as Pinarellos but not quite at 6.8kg either? :noidea:
Everytime Carapaz has attacked during this Tour, he came away gaining 0 seconds... at best!
spdntrxi
by spdntrxi
size 54 v3rs is ~7.3kg.. I'm sure UAE with tubs etc can get it to 6.9 if they want. This was for quick wheel changes.
bikewithnoname
by bikewithnoname
Yeah, did to see how much time Chaves lost today getting a front disc wheel change from neutral support? Burned a few matches getting back to the group uphill
outnumbered
by outnumbered
Carapaz probably gained a few more seconds on Uran with that tactic, but he certainly missed out on a stage win. Make that attack with 200m to go and he might have held Pog off.
OnTheRivet
by OnTheRivet
spdntrxi wrote:
Wed Jul 14, 2021 6:00 pm
This is what's so maddening, disc is no slower than rim. I switch disc wheels on one of my bikes all the time and it's easily as fast as my old rim brake bikes. The problem is the teams don't work on the process. Total Direct energie is the only team I've seen who have it wired. Mechanic got out with a drill gun and wheel and the rider knew what to do, it was crazy fast. If I was a WT team, every mehcanic and rider would spend a full day at training camp working on the process. Also, both wheels should have a handle for the axle so a rider can switch wheels between other riders if the team car isn't available. I'll say it now, INEOS will go disc, they will dial it in the off season creating special tools/equipment and will streamline the process to be the same or better than rim brakes and then everyone else will be "duh, why didn't we do that" and the whole wheel change thing will be a non-issue.
Dan Gerous
by Dan Gerous
Quick-Step usually can swap disc wheels quite fast too, probably not any slower than rim brake wheels, I think most teams who ride discs full time are pretty quick now... but if you use an axle that can be drilled out and back in quickly, you lose the possibility of riders being able to swap them between themselves in case no team or neutral service cars are nearby... and from the disc wheel changes I have seen done by Shimano neutral guys, they are not quite as fast with it as team mechanics.
dj97223
by dj97223
outnumbered wrote:
Wed Jul 14, 2021 6:04 pm
I suspect Carapaz was focused first on trying to gain time on Ving-go-go because Ving will be much better in the final TT.
DHG01
by DHG01
I would tend to think today's Colnago on rim was to get a bit of publicity and send message to the die hard rim brake fans that Colnago has a bike for them.
bikewithnoname
by bikewithnoname
Uran and Bilbao both warned for using illegal riding positions. Nicely inconsistent from the UCI once again given their rules stipulate both should be fined and disqualified.
They DQ'd Carapaz for supertuck earlier in the year without warning
maquisard
by maquisard
The penalty depends on whether the offence occurs in GT or one day race. GT carries more warning and fines for obvious reasons, the penalty is DQ in a one day race,
There is also context Carapaz occured during LBL and was stupid attempt to circumvent rules by "being clever". Uran looked like he briefly forgot what he was doing and then corrected himseld.
bikewithnoname
by bikewithnoname
maquisard wrote:
Wed Jul 14, 2021 8:02 pm
Have you've just made that up to have a dig at an INEOS rider? No mention of that GT distinction in the UCI release:
https://www.uci.org/docs/default-source ... ety-en.pdf
This one is even clearer, no GT distinction:
https://www.uci.org/docs/default-source ... .02.21.pdf
maquisard
by maquisard
UCI Commissaires are allowed to exercise judgement in the application of such rules.
It was stated that a rider would not be ejected from a GT for a minor offence, be it an aero-tuck or inadvertent littering.
Besides, the infringement by Carapaz was blatent and continous, Uran only very briefly assumed the position and then corectly himself. Hence the diffence.
