Current Bike Reach and Stack
- 367mm and 574mm
379mm and 530mm
Im wanting to try another bike, the Cervelo Aspero. I used to ride an R3 and loved it. Riding a Diverge now which is a little less aggressive.themidge wrote: ↑Thu Feb 13, 2020 8:14 pmMore or less, yes, a reduction in stack can be compensated for with spacers, although stack is a vertical measurement and the head tube is at an angle so it won't be exact.
You might need a slightly shorter stem since you're making the reach 1cm longer as well.
But why are you reducing your stack and keeping the same fit? Maybe if you want to get prograssively lower at the front end but otherwise, assuming your fit is fine at moment why change?
photocycler wrote: ↑Thu Feb 13, 2020 6:45 pmLooking at getting a new bike which has a lower stack height. The difference is 44mm. In order to retain my same fit, would I need to add 44mm of spacers to have the same bar height?
- 367mm and 574mm
379mm and 530mm
That is what I am trying to figure out, if it would end up being that many spacers.boots2000 wrote: ↑Thu Feb 13, 2020 9:30 pmBut please don't buy a bike that requires 44mm of spacers in order to fit you!
- 367mm and 574mm
379mm and 530mm
You'll almost certainly be better off getting a 54 and running a shorter stem. Or a different bike if you want it to be like the Diverge. It and the Aspero are opposite ends of the gravel spectrum.photocycler wrote: ↑Thu Feb 13, 2020 9:07 pmIm wanting to try another bike, the Cervelo Aspero. I used to ride an R3 and loved it. Riding a Diverge now which is a little less aggressive.
Most carbon Diverges come with a hover bar too, so that's even more. And if you have anything acting as a spacer in the Diverge, add that as well.That is what I am trying to figure out, if it would end up being that many spacers.
I am not runnign the raised bars so that is a non-issue. I was riding a 2019 Tarmac previous which fit, I am just liking the more rleaxed fit on the Diverge right now. With that said, I could lose a couple spacers on my current setup which is why I am trying to figure out how many spacers I would need just to get me back to where the diverge stack would be without spacers.Karvalo wrote: ↑Thu Feb 13, 2020 10:18 pmYou'll almost certainly be better off getting a 54 and running a shorter stem. Or a different bike if you want it to be like the Diverge. It and the Aspero are opposite ends of the gravel spectrum.photocycler wrote: ↑Thu Feb 13, 2020 9:07 pmIm wanting to try another bike, the Cervelo Aspero. I used to ride an R3 and loved it. Riding a Diverge now which is a little less aggressive.Most carbon Diverges come with a hover bar too, so that's even more. And if you have anything acting as a spacer in the Diverge, add that as well.That is what I am trying to figure out, if it would end up being that many spacers.
Weird that Cervelo's gravel bike has stack and reach measuements like a Madone.photocycler wrote: ↑Thu Feb 13, 2020 6:45 pmLooking at getting a new bike which has a lower stack height. The difference is 44mm. In order to retain my same fit, would I need to add 44mm of spacers to have the same bar height?
- 367mm and 574mm
379mm and 530mm
I just switched from an Allez Sprint and a Trek Crockett to an Aspero and went through about a month and a half of looking at different bike geometries before I made my decision.photocycler wrote: ↑Thu Feb 13, 2020 11:04 pmI am not runnign the raised bars so that is a non-issue. I was riding a 2019 Tarmac previous which fit, I am just liking the more rleaxed fit on the Diverge right now. With that said, I could lose a couple spacers on my current setup which is why I am trying to figure out how many spacers I would need just to get me back to where the diverge stack would be without spacers.
