Endurance frameset for rim brake
osw000
by osw000
Maybe a bit late... but just noticed that the shift to disk brakes is unavoidable in this category.
I still have to find a frameset from any major brand with endurance-gran fondo geometry available for rim brake.
pdlpsher1
by pdlpsher1
Option 1 a custom frame. Option 2 you can still find NOS Litespeed or Lynskey frames in rim brakes. Option 3 go used. There are probably other options as well. I went with option 1 and very happy with the result.
hlvd
by hlvd
I think you can still get the Domane SLR frameset in rim brake
sennder
by sennder
Sigma sports still has 2018 Domane SLR rim brake framesets in 52cm and 58cm in stock, almost half off. That's what I went with last year.
--sennder
robertbb
by robertbb
If you don't mind buying second hand (and can get frames scanned to look for any issues), the last of the rim brake Giant Defy SL's were an absolutely killer frame. In fact I think it may have been their lightest ever frame - uses the same carbon/resin as the TCR but has the more relaxed geometry.
Dropped seatstays too, so a thoroughly modern look. Might want to check tyre clearance if you like to run on the wider side.
https://www.giant-bicycles.com/au/defy- ... -sl-0-2014
mcfarton
by mcfarton
But won’t you die on rim breaks?
njyeti
by njyeti
mcfarton wrote:But won’t you die on rim breaks?
Yes, if the rim breaks you'll die
Sent from my SM-G975U using Tapatalk
gorkypl
by gorkypl
Cinelli Veltrix
iamraymond
by iamraymond
The Canyon Endurace is still offered with rim brakes. The geometry is a bit more relaxed than the disc models and the frame is a few years old now. However it’s still a decent bike. It’s offered in both mechanical and electronic builds so if you want to strip it down and build one up, then be sure to get the right model. It’s not offered as a frameset only.
