Home grown chain lube.....no, not the religious way ;-)
I got 3 chains rotating at 500km interval between 2 cassettes totaling 15500km. Park Tool CC-4 measures them still a long way to the 0.5 wear mark. Do you think I can get 24000km out of this set of chains and cassettes?
I find the need to resurrect this thread when I see people arguing the use of food grade paraffin or candle wax, PTFE or not, etc...
I did that exactly in a recent 6-day tour. Heavy rain first day and the chain started to squeal slightly at the end of the 2nd day. Got baby oil in convenience store and applied it to the chain, wiped excess and let "dry" overnight. Chain stayed "lubed" the following days and easy cleaning back at home. No chemical was used other than warm water and detergent with a tooth brush to clean the cassette and pulley wheels. The chain will be lightly cleaned later and taken out of the pool of 3 chains for the next trip.MrMagura wrote: ↑Mon May 20, 2019 10:46 pmNothing else than xylene really works. Been there, done that. Turpentine evaporates very slow, and attacks some types of paint.
Toluene is not much nicer to be around than xylene, and is also not dissolving proper.
When applying lube, you also need to clean the chain somehow, and that takes about as long as just hot dipping the chain, and let the lube clean the chain.
If you just aplly lube without making sure the dirt gets out of the chain somehow, you in fact bring the dirt into the bearings.
Having said that, neither brings much adhesion, where hot dipping the chain is far superior.
If you want to have some kind of emergency lube, just use plain paraffin oil.
I have not run into that issue for years though, as I simply make sure to have a few lubed chains ready at any time.
If a chain runs out of lubrication, it's mostly dirty as well, so pouring lube on is not a good idea, as that creates a grinding compound, rather than lubing the chain.
All you gain is that the chain stops screaming, but in fact the net result is not really better.
I have one as well And I use it when buying vintage bikes for restoration. It saves me a lot of searching and also money.
Cannondale Super Six HiMod 2017 6.7 kg
Cannondale six13, 2004, 5.50kg
Focus Izalco Max, 2023 4.418 kg
