On the market for a new bike...need your help/input fellow ww!
seaneT1
by seaneT1
I am looking for a bike that has ALL of the characteristics that I will specify below, or at least one that gets really close. The bike will be used for serious racing.
- Disc brakes
- Aero
- FULL integration ( NO CABLES.! )
- Di2
- The budget is around 6 to 7 thousand euros
- Must be close to 7 kilos fully built,( the final goal with some minor upgrades as times passes is to have sit at around 6,8 to 7 kg), NO more than 7,6 kilos for a size 54, and if it is around 7,3 to 7,6 kilos and inside the budget mentioned above, there must also be the option of lowering the weight in the future to around 7 kilos with spending another 1000 to 1500 euros let's say... ( example: Dura ace build bike is 7 kilos, but costs 10 thousand but same bike with ultegra is 6 thousand and is 7,5. Not a problem since I can upgrade in the future when I will have more money and drop the weight to 7 kilos or under! )
Thus far, the only bike that ticks all of those boxes that I know of is the venge, but I am sure that there are a lot more out there ( cervelo s5, bmc timemachine, cannondale systemsix, other lesser known companies etc... )! So please, help me find them, and please, PLEASE!!! DO NOT POST BIKES AND SUGGESTIONS THAT YOU THINK IS BETTER BUT ARE NOT RELATED TO WHAT I AM LOOKING FOR, I AM VERY SPECIFIC ABOUT WHAT I WANT SO PLEASE DO NOT TRY TO CHANGE MY MIND OR SUGGEST ME OTHERWISE!!!! Thank you :)
Marin
by Marin
Sounds like an easy research, why not do it yourself?
dim
by dim
Canyon Aeroad ?
Trek Emonda SL6
Miyata One Thousand
seaneT1
by seaneT1
Marin wrote:
Thu Dec 20, 2018 11:42 am
It is actually not an easy one since many information about different bike models are not available, for example the real weight of a size 54 venge pro ultegra di2...no site has it but someone here might know it. Also there are many brands out there and so many models, and there are also new ones that are coming out later in 2019 and that I am not aware of...
seaneT1
by seaneT1
dim wrote:
Thu Dec 20, 2018 12:57 pm
Canyon Aeroad ?
Would be perfect IF ONLY it was fully integrated, meaning NO CABLES SHOWING!!! But they have the go outside the frame unfortunately...Also, I believe that they are about to update it soon, so definitely not going to buy one now just to have a better updated model pop up a month later, that would not feel nice...
TiCass
by TiCass
Venge Pro, Ridley Noah Fast, Cervelo S3
But I don't think you can expect 7kg with Ultegra DI2.
seaneT1
by seaneT1
TiCass wrote:
Thu Dec 20, 2018 3:04 pm
Yeah, I know, but if it still is around 7,5 to 7,6 with ultegra, I can live with that, knowing that I can upgrade it when I have the money :)
DJT21
by DJT21
Focus Izalco Max Disc
Trek Madone
Two off the top of my head.
seaneT1
by seaneT1
DJT21 wrote:
Fri Dec 21, 2018 9:00 pm
Trek Madone
Trek mad one I think is not an option since it is way heavier and pricier than what I am looking for. Focus might be another good option, but there aren't many real world info about it yet...
DJT21
by DJT21
seaneT1 wrote:
Fri Dec 21, 2018 10:42 pm
Trek Madone
The Focus doesn't look like it's been designed as an out and out aero bike, but it's hard to quantify unless someone tests it along with all the other bikes. With all of the hidden cables, it could be more aero than say a Giant Propel (that is marketed as an aero bike) with cables flapping all over the place.
I like the look of the Focus, and especially the BMC (but the Team Machine, not the Time Machine).
bm0p700f
by bm0p700f
Look 795 rs blade disc. I think that ticks boxes.
SchallUndRauch
by SchallUndRauch
DJT21 wrote:
Sat Dec 22, 2018 11:26 am
The Focus will certainly be tested in the TOUR magazine sooner or later, then we'll know its aero properties.
SchallUndRauch
by SchallUndRauch
bm0p700f wrote:
Sat Dec 22, 2018 11:36 am
Hmm, not to be found online.
bm0p700f
by bm0p700f
I am sure i saw it at eurobike.
The 785 huez rs disc while not strictly an aero bike should be quite aero if your in a good position.
Noctiluxx
by Noctiluxx
Giant Propel Advanced SL 1 Disk. Its a little heavier than your specs due to Ultegra Di2 but would meet your demands with DA 9170. BTW, it also comes with a dual side power meter.
https://www.giant-bicycles.com/us/prope ... -sl-1-disc
Japanese site below tells you the weight
https://www.giant.co.jp/giant19/bike_da ... d=00000002
2018 Bianchi Oltre XR4, (Celeste Matt)
2018 De Rosa SK Pininfarina (Blu)
2019 Trek Madone SLR (Rage Red)
2019 Giant TCR Advanced SL (Chameleon Blue)
2019 Giant Revolt Advanced 0
