Thru axle on rim brake road bikes?
Champ5000
by Champ5000
Hi guys
Do you think thru axle on rim brake road bikes will become standard from the big companies in the comming years?
Marin
by Marin
I hope not, because why?
jfranci3
by jfranci3
No. Disc frames, forks, rims, and hub bodies are of a different design in all cases. TA's cost a lot more than QRs on the frame and skewer side. You also get a lot more QA issues with TAs as they need to thread the fork/frame or put a insert in. If they want more clamping power, they'll just use a DT Swiss RWS bolt or similar.
I've got DT Swiss 12mm TAs on my disc road bike. They're f-ing fantastic with the exception of fork mounted roof racks. For daily use, they are far easier to get the wheel on/off than QRs as they don't have "lawyer lips". My QR trek needed the QR released then spun 3-4x to get the wheels off for example. With a TA with the lever attached, it a lot less effort.
