Any feedback on the garmin speed and cadence sensors (the magnetless ones)
Delorre
by Delorre
Calnago wrote:
Fri Jun 29, 2018 1:55 pm
Since they don’t make the GSC-10 anymore I’m using the Wahoo sensor... it’s small and easy to fit, and looks good I think.
The magnet one? The magnetless is not less bulky than the Garmin one🤔
Calnago
by Calnago
@Delorre: Yes, the magnet one... very similar to the discontinued Garminn GSC-10 in function and setup...
mdeth1313
by mdeth1313
I tried out the magnetless sensors today. About 4 times my garmin "auto paused" and then immediately "auto resumed". Otherwise they worked flawlessly.
Speedplay is the devil!
otoman
by otoman
Hey Calnago, you may want to flip that sensor to the underside of the chainstay. The reason to put it on the underside is that if it ever gets bumped in while mounted there, the spokes will just knock the sensor back out. With it mounted in the top, if it gets bumped in the spokes will catch it and yank it in, possibly breaking it and some spokes.
Age and treachery shall overcome youth and skill
Calnago
by Calnago
No... I have it like it is for that very reason. If on the very unlikely chance the spokes has r magnet hit the arm, they will just slide off it as they go by. Versus when the arm is pointed up, it would be much easier for the magnet or spoke to just jam into it. And have bad things happen.
But maybe you mean mount the entire thing underneath on the bottom side of the chainstay? Trouble with that is the articulating arm would kind of be backwards. And the ugly battery side would be exposed. And the indicator light would then be on the inside (talking about the Garmin GSC-10 now).
Just this minute got back from a ride. Here’s the Garmin setup...
I think (would have been years ago now) I looked into mounting it underneath but it was awkward at best.
I’ll take a look at the Wahoo setup tomorrow.
Used to see so many Pro setups with the speed sensor on the back of the front fork and is just cringe thinking about the sensor getting knocked into the spokes versus if the sensor was not the front of the fork leg it just gets pushed away in that event
Thing is, these sensors are so solidly mounted they’re not moving. But thanks, cuz those are exactly the kinds of things I always try to think of when mounting things like that.
taodemon
by taodemon
I never had issue with either of them. Battery replacement about once a year. The cadence sensor has moved to the trainer bike since my recently acquired power meter has cadence built in. I've ridden without the speed sensor when I've forgotten to change the battery for a month straight but I don't like how the speeds can be inconsistent based on gps alone.
seanlsc
by seanlsc
Im using garmin speed sensors now. It can be quite inconsistent at times and speed reading fluctuates pretty often. Does anyhow experience this??
AndreLM
by AndreLM
Calnago wrote:
Mon Jul 09, 2018 4:18 am
I don't know how one could "elegantly" mount the GSC-10 or the Wahoo combo mount under the chainstays. One option if you already have a PM with cadence reading is to use Bontrager's speed-only sensor. I think this one certainly looks better when mounted underneath the chainstays.
As a side note, they come with a couple of different sized rubber bands which are more gentle to the frame finish, and also easier to remove for cleaning (but can also be mounted with zip ties). They let the sensor move more easily though: I got it knocked out of place (and not picking up the magnet) a couple of times when placing the bike inside the car with rear wheel off - it was just matter of remembering to put it back in place.
Frankie - B
Administrator
by Frankie - B
mdeth1313 wrote:
Mon Jul 09, 2018 2:28 am
Did you place it in your front or rear wheel? When mounting it in the rear wheel, the distance between the sensor and the computer can be to long. hence the dropping in readings.
Please follow me on Instagram
11.4
by 11.4
I had mixed problems with the Garmin magnet-less sensors. They use accelerometer chips that I found would miss revolutions. The one on the crankarm was only dealing with up to 160-170 rpm on a track crank, and yet it would have frequent blips where it would lose one revolution. This doesn't show up as an obvious data gap, but it does mess up your overall data.
Plus, they are hideously ugly. I use the GSC-10 or the Wahoo equivalent. (On the track you can't reliably use GPS data because of resolution is down just a bit, or even if the computer is trying to average data points, the tracks can look really odd on anything but a very big track.)
RTW
by RTW
I use the cadence ones. Put a blob silicon sealant on the 'Garmin' side, (the 'wrong' side) and then press it against the inside of the crank arm. It will stay put 100%, and for battery changing you can open the battery cover which now faces out.
Looks WAY better.
Agree the speed sensor is an ugly MoFo. I put it on the back hub so I don't have to see it.
MikeD
by MikeD
mdeth1313 wrote:As my GSC-10 speed/cadence sensors are getting older, I was looking at the magnetless speed/cadence sensors that mount on the hub and crank arm. Does anyone have any feedback on their performance, lifespan, etc and or comparison to using the GSC 10 with magnets?
Thx...
I have both. The GSC-10 is cheaper, uses 1 instead of 2 batteries, and its battery life is better.
