Question about speedplay
addictR1
by addictR1
Just bought a pair of speedplay x1. eBay seller listed it as 144g for a pair. Much lighter than my current eggbeater Ti.
Here’s a stupid question. This is my first set of speedplay and not sure what version of cleat I need. There seems to be so many different versions available. Also do you need a shim to mount to 3 hole?
Lastly, where can I find a pair of cleat for cheap? Slickdeals anywhere?
IrrelevantD
by IrrelevantD
You need X-Series cleats. They will come with everything you need to mount them to 3-bolt shoes. Do not confuse them with Zero cleats. There is a different spring mecanism and they are not compatible between the two.
Link below to Performance Bike, was the first one that came up in a google search, but there are others that cary it.
https://www.performancebike.com/shop/sp ... ts-62-4085
addictR1
by addictR1
mods please delete.. i had issues with tapatalk and accidently posted twice
