Garmin, Strava problem.
KCookie
by KCookie
Hi Guys,
Just seeing if you can help me out.
I've got a Garmin 520 which is paired to my phone, I've never had a problem until Saturday. I came back from a ride stopped the Garmin pressed save activity as normal, now normally buy the time I walk in doors my phone then says activity uploaded to strava. All good, but not this time and on today's ride. So obviously I'm pissed off not seeing any data, twice now.
So I started and stopped the Garmin and on the fifth go it uploaded to my phone, obviously no data, just 0 miles etc, so it does work just not when I'm finishing my ride.
Has this happened to any of you.? Any thoughts.
Next ride I'll make sure I have strava going on my phone.
P90Puma
by P90Puma
Check garmin connect to see if the activity is there.
Also if you plug in your garmin to your pc the activities are saved on the device as a backup as well and you can upload from there.
KCookie
by KCookie
For some reason it's not showing on Garmin Connect, so I'll have to plug into the PC.
Will I then be able to share it to Strava. ?
Cheers
brackc
by brackc
In the past I've had trouble with the garmin syncing to the phone app, if you delete the app and re-install it you will re-connect to the garmin servers, which can solve some issues.
KCookie
by KCookie
Ok I'll try that first.
Cheers
joejack951
by joejack951
Shut down and restart your phone. It should then show up in Garmin Connect after syncing. Then manually upload the activity to Strava (download the .gpx file from Garmin Connect and use the uploader for Strava). Just went through this with my FR35 after months of no issues.
KCookie
by KCookie
joejack951 wrote:Shut down and restart your phone. It should then show up in Garmin Connect after syncing. Then manually upload the activity to Strava (download the .gpx file from Garmin Connect and use the uploader for Strava). Just went through this with my FR35 after months of no issues.
To manually upload am I right in saying id have to plug my phone into my laptop. Sorry I'm shit at technology.
Frankie - B
Administrator
by Frankie - B
No, you need to connect your garmin to your laptop and upload the .fit files to strava.
Please follow me on Instagram
KCookie
by KCookie
Frankie - B wrote:
Thu Apr 12, 2018 9:47 am
Awesome, many thanks for that. !!
KCookie
by KCookie
I've got the files up on my laptop but how do I transfer them to Strava.
KCookie
by KCookie
All done guys, thanks alot for your help.
Frankie - B
Administrator
by Frankie - B
Great job!
