Paint finishing help
FilmAt11
by FilmAt11
I’ve painted a fork with (4) coats color, lightly wet-sanded with 1500 grit, applied decals, then (2) light coats and (2) medium coats of glossy clear coat.
I’d like to reduce the decal edges and polish to a glossy finish, but I’m unsure on the best approach.
I’m considering wet-sanding to reduce the edges and texture overall, then polish to finish. Is this correct?
Do I have sufficient clear coat?
Thanks
euan
by euan
You will struggle to get a flat glossy clearcoat with aerosol cans without extensive flatting back and polishing.
My opinion, you've still got quite a pronounced edge on the decal which tells me that your coats just weren't wet enough.
I would flat back carefully dry sanding to make sure you don't accidentally rub through. Just enough to key the surface. One light misting coat then two wet coats.
Once this is cured hopefully this will be enough for your to wet sand the orange peel flat with your 1500 and if you get get it 2000 and then use a cutting compound to polish it.
"Step forward the climber and all those who worship at the altar of lightness" - R. Millar
FilmAt11
by FilmAt11
Thanks euan, appreciate the post.
glepore
by glepore
Excellent advice above.
You need finer than 1500 -final sanding with 2000. To really polish it it should be clamped in a fixture and hit with a rotary buffer and either a 3m or Meguier's product designed for that purpose. You can get an ok finish with hand polish but not killer.
Cysco Ti custom Campy SR mechanical (6.9);Cannondale SS Evo Di2 7970 (5.79); Willier Cento Uno Air Di2 9070 (7.0); C40 Mk2 DA 7800 ; Anvil Custom steel Etap;1996 Colnago Technos Record
