Simplex 6600 Super LJ derailleurs
liam7020
by liam7020
In the process of renovating an early 80s Peugeot and hoping to use Simplex 6600 Super LJ front and rear derailleurs. Anyone know the maximum size of sprocket that can be used with the rear gear and the max range that can be used with the front gear? Cheers.
Belgian Flag S-Works Tarmac viewtopic.php?f=10&t=144553
Kurets
by Kurets
Before looking it up I would have assumed 26t max in the rear. However according to the Disraeli Gears derailleur collection site the max sprocket is 24t with a 22t takeup capacity. Assuming a standard 52/42 up front this would give you a range of 12 for the freewheel allowing for a 12-24 freewheel at the largest.
[URL="http://www.disraeligears.co.uk/Site/Simplex_Prestige_Super_LJ_derailleur_SLJ6600.html"
]Disraeli Gears derailleur collection[/URL]
liam7020
by liam7020
Yeah I would thought 26 but I read another forum where a guy said he got the Simplex gear to work with a 14-28 standard width 6 speed freewheel but not a narrow 6 speed. Now I was hoping to use a 14-28 7 speed freewheel - wonder does that equate to a narrow 6? Not sure so may have to suck it and see.
Kurets
by Kurets
I'm sceptical. Old road gearsets are not intended for big cassettes. I don't think running a 14-28 would be a good choice as you are outside the takeup capacity by 2 links and above the max sprocket by 4. Get things which are suitable for what you want to instead of forcing granny gears onto a racing derailleur.
liam7020
by liam7020
I'll let you know how it pans out.
liam7020
by liam7020
Kurets wrote:I'm sceptical. Old road gearsets are not intended for big cassettes. I don't think running a 14-28 would be a good choice as you are outside the takeup capacity by 2 links and above the max sprocket by 4. Get things which are suitable for what you want to instead of forcing granny gears onto a racing derailleur.
So before sending the Peugeot off for respraying/rechroming I wanted to trial a few freewheel combinations, thus when the frame returns in about 20 weeks time I'd be set to start building without any messing about. By sheer chance I found a 7 speed 14-28 freewheel in the bargain bucket at Halfords for the princely sum of £1! I mounted it on the Campag hub, tweaked the Simplex (Gipiemme) derailleurs a tad and hey presto, it works. Now it ain't perfect but it certainly is completely functional. The reason for the "granny gears" is that I'm hoping to ride the Eroica Gaiole next October and I'm pretty sure I would struggle to haul my aging ass up those Tuscan climbs in 42x24 but with 42x28 there's a chance!
I started spannering at bikes 6 years before this frame was built and the one thing I've learned in that time is that occasionally you have to ditch the manual, have a tinker and see how it turns out!
