Shopping for front and rear lights
kode54
by kode54
leej88 wrote:I have both the Lupine Rotchlit and the updated Cateye Rapid x3 (150 lumens).
Both rear lights have similar lumen output but the Cateye appears much more visible as the throw is wider.
The accelerometer and light sensor on Lupine is rather gimmicky imo.
i don't feel that the accelerometer is gimmicky. its nice that it goes solid red when braking...and most drivers pay attention to out of the ordinary blinking.
also, there are 4 or 5 brightness levels and depends on how far i ride...i'll turn it mostly on the second to highest level for visibility.
well made and the saddle rail mount has been great, so i can switch between bikes quickly.
- AX Lightness Vial EVO D + DA9150 + Enve SES 3.4 carbon hubs
- Parlee ESX + DA9150 + THM SRM PM + Enve SES 6.7 CK hubs
- Independent Fabrication Ti FLW + DA9100 + Enve 3.4 CK hubs
TonyM
by TonyM
I just saw this front light that can be mounted between the Garmin mount and the Garmin itself!
Fabric Lumaray.
https://fabric.cc/products/lights/lumar ... ont-light/
junchen
by junchen
TonyM wrote:I just saw this front light that can be mounted between the Garmin mount and the Garmin itself!
Fabric Lumaray.
Nice! Tks for sharing
Sent from my Redmi Note 4 using Tapatalk
jimaizumi
by jimaizumi
I have a front Bontrager light and honestly, for a small light, its really bright!
:oops: THE PAST: 2005 Cannondale R700, 2006 Specialized S-Works Tarmac Gerolsteiner, 2009 Pinarello Dogma FPX My Way, 2011 Time RXR VIP
:D THE PRESENT: 2016 Colnago C60 ST01, 2017 Wilier Cento 10 Ramato
:wink: THE FUTURE: :mrgreen: :mrgreen:
dim
by dim
Front Light:
Ravemen PR1200 USB Rechargeable DuaLens Front Light:
http://road.cc/content/review/221409-ravemen-pr1200-usb-rechargeable-dualens-front-light
costs £100 and is a very good light
However, if you want something powerfull, and cheap, get the Chinese SolarStorm off ebay, but the get new ones that work off a powerbank:
https://www.ebay.co.uk/itm/15000LM-SolarStorm-3-x-CREE-XM-L-T6-LED-4-Modes-USB-Bike-Bicycle-Light-Headlamp-/282746253815?
cheap as chips and it's less than £10 .... get a good small powerbank (lipstick size) and use the light on your helmet with the powerbank tucked in your pocket .... thats what I do and the light is as strong as a Volvo Bus headlight (I commute throughout winter in the dark on crappy unlit roads)
As for the back light, you can't go wrong with a Cygolite Hotshot .... I've been using mine daily for 3 years and you can see it a mile away:
Giant TCR
Canyon Endurace AL
Specialized Allez Sport
Vagabond
by Vagabond
nickf wrote:Light and Motion VIS Pro rear (150 lumen w/day flash) and a Urban 800 on the front. Both are self contained and bright. They even have a small urban series 1000 lumen headlight. On high you only get around 1.5 hours. But depending on what you are doing you might get away with a lower setting. Can't cheap out on safety. My light almost never come off my bike. The light and motions units are light enough for me.
I use the High Vis as well and and have both an Urban 600 and 1000 for the front. Great lights. Weatherproof, easy to mount, good battery life, and plenty of illumination. In fact when I’m using the 1000 I don’t think I’ve ever passed a brighter light here in the bicycle commuter abundant DC area. I really like the mounting system for the Vis 180 and the way it straps on to the seatpost. I use it more and more back home even during the day on the rural roads I ride in Washington State even in daylight. Around 120 dollars for the Vis tailight and Urban 1000 together if I remember correctly. Let us know what you go with.
Colnago e Campagnolo
bilwit
by bilwit
Fabric Lumaray.
nice.. know if it works with the Elemnt Bolt?
Johnny Rad
by Johnny Rad
Fabric Lumaray.
You've uncovered a potential gem! Thanks for sharing. Wished it had more operating life, but... Trying to place my order.
Would be ideal if someone made a double-sided out front mount... I'm off to re-read our marathon post on the subject now.
dim
by dim
4hrs ride in the dark? ... you will need to carry batteries.... or get a dynamo hub built on your front wheel
or .... for cheap, get a Chinese Solarstorm that works off a powerbank .... use it with the headband and get 2 small lipstick sized powerbanks:
https://www.ebay.co.uk/itm/15000LM-Sola ... SwYlRZGs8Y
Giant TCR
Canyon Endurace AL
Johnny Rad
by Johnny Rad
dim wrote:4hrs ride in the dark?
I don't want to charge it every other ride. :D
I always ride with blinkers front and rear now.
For convenience, I prefer CR2032-powered lights.
If it's dark out, I break out a higher-powered front light.
jfranci3
by jfranci3
As a data point, I've tried the new-ish Specialized Stix lights. Battery life on the "Comp" 3-light units is about 1/2 the quoted life; about 2.5-3hrs f and r. They have a newer "Elite", which I haven't tried. SPC sent
me one, to their credit, after I complained, though it was to the wrong address. They are, as the specs show, "Be Seen" only lights. The mounting system is IMO great, mounting directly to the seat and stem spacers.
nickf
by nickf
Johnny Rad wrote:
Sun Dec 17, 2017 4:52 pm
Fabric Lumaray.
Dunno 30 lumen is on the low side. Even in the video it seems kinda weak. Ok if you just wanna be "legal". As for a piece of safety equipment I don't think so.
jfranci3
by jfranci3
30lum is fine for "be seen" lighting except for sunrise / sunset, which no light is good for.
