Garmin Edge 820 Discussion Thread
reknop
by reknop
Question to the Garmin Edge 820 users.
Can you set the left/right balance now, if you are using a single power meter?
On my Pioneer SGX-CA500 I can manually set the left/right balance value.
https://www.remo-knops.com/cycling/
saeie1
by saeie1
Garmin Edge 820 reduced weight and size to 2.3 compared to existing products, making it easier to see the screen.It is easier to operate on the dashboard than it is when it is operated by a push-button that is not operated.
Though I am currently Edge 520, I would like to upgrade to Edge 820.
jipperd
Moderator / Brake Pad Boy
by jipperd
What are your experiences with the real life battery life.
1) While only registration of the ride?
2) While navigating?
Mockenrue
by Mockenrue
1) On this ride I was just recording and I had about 35% left at the end iirc.
2) On this ride I was recording and navigating and I got the low battery warning about 10km from the finish.
Those are the longest two rides I've done with the unit. On both occasions it was paused and left on during stops.
TonyM
by TonyM
7,5 hours ride with GPS/ Glonass on, speed on, etc...but no navigation on and at the end of the ride the battery had 58% (fully charged at start).
zev
by zev
Good to know the battery is working well, thanks.
zev
by zev
saeie1 wrote:Garmin Edge 820 reduced weight and size to 2.3 compared to existing products, making it easier to see the screen.It is easier to operate on the dashboard than it is when it is operated by a push-button that is not operated.
Thanks for the review
