Garmin 1000 map question
jever98
by jever98
I have a Garmin issue I couldn't find an answer on (or my searching skills suck).
On a Garmin 1000 I tried, I have an issue with mapping: I would like the map to display the smallest types of paved roads (grey solid line, typically visible from 800m and closer) at 1.2km resolution, but without displaying land cover and all sorts of other information, because then I can't read the map anymore. Whilst riding. The reason I want this is that we have a ton of small roads in Switzerland that can make for great riding, and would have more of an overview.
If I change the map detail level, the roads appear or disappear (appear on level "more" or higher, disappear on "normal" or less). However, nothing changes with regards to the other detail, whether I set "land cover" to off or not.
Ideally, I would like the Garmin to only show the different types of roads (like it does on, say 2km resolution), but including the really small ones.
Any Garmin experts out there who can advise?
Cheers
Jever
No longer in the industry
havana
by havana
Simply not possible AFAIK.
Most "innovations" in cycling are solutions for non-existing problems.
jever98
by jever98
Thanks for the info.
:( that really sucks.
LloydP
by LloydP
I think it's a map issue rather than a device issue. Probably could be done if you're handy with making map tiles, but more trouble than it's likely to be worth. Or try a different source of maps, openfietsmap or whatever
Herb5998
by Herb5998
Is your base map file from Garmin? You could try using open street map (bike routable) and that may help. DC rainmaker has a how to on his website.
Guerdi
by Guerdi
No, it is not possible unfortunately.
What maps are you going to use ?
I can vouch for garmin topo Switzerland v3 raster version (not the latest v4), which comes in handy for smaller roads. Also the routables OSM for bikes (Openfietsmap Lite) do a good job.
jever98
by jever98
Thanks - the Garmin I tried has the Garmin Cycle map on it.
I'm a bit sad, because in the end the Garmin 1000 doesn't really offer much functional benefit over my 5 year old 800. Yes, the screen is nicer and bigger, but I find it makes very poor use of the additional resolution in terms of mapping. By not being able to strip out unwanted detail it becomes too cluttered.
Does anybody know what the function "land cover" does in the end?
Cheers
