Camera Mounts and Assorted 3D Printed Parts
xterrastrial
by xterrastrial
Thx!
orange77
by orange77
Hi,
Can't you make an "aero" version for a Edge 520? (Similar to the Bolt (I've searched and didn't find)).
Thanks :thumbup:
WheresWaldo
by WheresWaldo
@orange77 I am not sure because of the shape of the bottom of Garmins devices I am not sure how to integrate that option.
xterrastrial
by xterrastrial
WheresWaldo wrote:Sure, give me 24 hours
I have digital vernier calipers. Let me know if I can help by measuring anything on my BMC mounts. Thx.
PaulH
by PaulH
Do you have a blendr high go pro mount , I can only see the low?
xterrastrial
by xterrastrial
PaulH wrote:Do you have a blendr high go pro mount , I can only see the low?
Select the "Small" instead of "Medium" option on Shapeways.
WheresWaldo
by WheresWaldo
Hey Paul, something like this?
xterrastrial
by xterrastrial
WheresWaldo wrote:Hey Paul, something like this?
Yes!
WheresWaldo
by WheresWaldo
Before I upload it want to make sure the BMC uses the GoPro standard. Secondly does BMC have a name for their mount ie Bontrager Blendr, Fizik I.C.S., Topeak Quikclip, etc.?
xterrastrial
by xterrastrial
WheresWaldo wrote:Before I upload it want to make sure the BMC uses the GoPro standard. Secondly does BMC have a name for their mount ie Bontrager Blendr, Fizik I.C.S., Topeak Quikclip, etc.?
Re: the GoPro std, the "double" mount in the press pic I had posted has the same interface for the top and bottom attachments, and they show/advertise the bottom being for GoPro's, so I have to assume they both are.
The system is BMC's ICStem integrated mount.
http://www.bmc-switzerland.com/int-en/i ... it-system/
Finally, here are some pics of my current ICStem integrated mount with calipers if that helps at all.
orange77
by orange77
WheresWaldo wrote:@orange77 I am not sure because of the shape of the bottom of Garmins devices I am not sure how to integrate that option.
Hi Waldo,
Ok, thanks :)
WheresWaldo
by WheresWaldo
Paul,
It's done and up on the same page as the rest of the BOLT Aero mounts, so you go and choose accordingly, BOLT Mounts
Extra Small = BMC ICStem Mount (This should also fit the upper Bontrager Blendr mount)
Small = Bontrager Blendr High Mount (This approximates the overall dimensions of the OEM Garmin High Mount)
Medium = Bontrager Blendr Low Mount (This approximates the overall dimensions of the OEM Garmin Low Mount)
xterrastrial
by xterrastrial
WheresWaldo wrote:Paul,
Ordered! Thx!
WheresWaldo
by WheresWaldo
Uses a couple of zip ties to hold it in place. When the fellow cyclist that asked for this sent me a picture of it installed, I was surprised to see it mounted in front of the saddle clamp instead of behind the saddle clamp.
WheresWaldo
by WheresWaldo
Just got these images from someone who wanted a mount for their SWAT equipped saddle
For us weight weenies the mount without the screws weighed in at 6 grams.
