Camera Mounts and Assorted 3D Printed Parts
kode54
by kode54
WheresWaldo wrote:@kode54 here they are.
http://shpws.me/SKxq
http://shpws.me/SBP9
Fitment of the Di2 junction under Garmin mount was spot on. Excellent 3D printing and all. Thx so much Bud!
- Factor Ostro VAM Disc
- Factor LS Disc
- Specialized Aethos Disc
- Sturdy Ti Allroad Disc
- Guru Praemio R Disc
kode54
by kode54
The Strada Varia mount was also great, although the actual mount could be moved up 15mm and 7mm closer to the post. If you made those changes, I would buy that to replace the one I just received.
With the changes, it would hide the actual mount from behind so you wouldn’t see the bolts.
- Factor LS Disc
kode54
by kode54
Here’s one with the Varia on so you can see what I’m talking about. Maybe even 10mm closer to the seatpost. I know probably the top bolt may get in the way but as high up as possible.
- Factor LS Disc
kode54
by kode54
- Factor LS Disc
WheresWaldo
by WheresWaldo
@kode54
I will work on something next week. Been offline for a few days as I was building a new PC (only took me 15 months to wait for a GPU). I have everything finally set up, so I can get back to it soon.
kode54
by kode54
Thx Bud. No worries. Just fine tuning.
Hope you get it up and running! GPU are more difficult to get than derailleurs!
- Factor LS Disc
WheresWaldo
by WheresWaldo
@kode64, I managed to get this finished this morning.
It is at the same link as before, http://shpws.me/SBP9. I left it still rendering the model images.
It is 11 mm higher and approximately 5 mm closer to the seat post (maybe even closer than that).
kode54
by kode54
That is perfect. Will order and post a pic when I get it. Thx again!
Any chance to get the Varia Saddle Rail mount to be slightly lower? It hits the Gelu saddle a bit. Need that about 10mm lower. Here's a pic in the next post.
- Factor LS Disc
kode54
by kode54
- Factor LS Disc
kode54
by kode54
- Factor LS Disc
WheresWaldo
by WheresWaldo
Yeah, I can make a variant that is 10 mm lower.
kode54
by kode54
Great! Thx Bud.
- Factor LS Disc
WheresWaldo
by WheresWaldo
@kode64
Added this as a variant. Make sure you chose MEDIUM
http://shpws.me/RX8V
kode54
by kode54
Awesome Bud. Thx again!
- Factor LS Disc
WheresWaldo
by WheresWaldo
I thought I would post this here as it is an interesting look at using the HP MultiJetFusion printer at Shapeways.
https://www.shapeways.com/blog/archives ... beads.html
Please note that PA12 with glass beads is only available for any model you personally upload and is not a Public facing material.
