Camera Mounts and Assorted 3D Printed Parts
- WheresWaldo
- in the industry
Without actually having the SWAT toolkit and no friendly (and stocked) Specialized dealers in my area, I wouldn't even know where to begin. I am sure it is possible, I just wouldn't be able to do it at the current time.
Would it be possible to send it to you? Can I pm you?WheresWaldo wrote:Without actually having the SWAT toolkit and no friendly (and stocked) Specialized dealers in my area, I wouldn't even know where to begin. I am sure it is possible, I just wouldn't be able to do it at the current time.
- WheresWaldo
- in the industry
@WheresWaldo
I have two of your Bontrager Flare SWAT mounts (canted version), and really happy with them, great job! I recently got one (https://www.shapeways.com/product/BJ8NR ... arketplace) for the Pro Stealth saddle I am using, and the quality is good as expected, but I wish it was positioned higher and closer to the saddle. Is this something you can/would do? Pictures to show what I am after:
How it is currently positioned
Where I would like it to be positioned
I understand the "long" version is adapted from the original, which sits under the saddle, hence needs to be low, but there isn't the same restriction with the extended position, and would be nicer(and less flexy) if the light sits higher and closer to the rear of the saddle.
- WheresWaldo
- in the industry
@wannabefast
I can work on something like that, give me a couple of days to work something up. A question for you can you estimate the difference in degrees to get the Flare perpendicular to the ground, if looks like it is 2° - 3° but I would like a better measurement.
@WheresWaldo
I am not sure any adjustment to the angle is necessary, it's actually pretty perpendicular to the ground currently, I think it was my saddle bag that was pushing it up slightly (perhaps the "arm" can be made a little thicker to make it stiffer?). I did a quick check with the level on my phone, it is angled up maybe 1 degree, hard to be super precise.
See the mount on its own:
Hopefully a more clear pic of where I am hoping the new position will be:
Let me know if you have any more questions or want to take it to PM.
@WheresWaldo
I decided on whim to try the closer set of holes just to see how it looks, even though I didn't think that would accomodate the saddle bag. But lo and behold, the saddle bag still fits. I am good with how close this sits, even if a slightly higher position might look better to my eye, it's a pretty marginal improvement.
Thanks for entertaining my questions, and don't bother working on a new mount just on my account, unless you want to offer another option to others!
How it looks now
How it looks now
- WheresWaldo
- in the industry
@wannabefast
Glad it worked, and now you see the reason I included an extra hole in the top section.
- WheresWaldo
- in the industry
New mounts available
- Cippolini MCM Allroad Single Bolt Varia Mount - http://shpws.me/SUT3
Parlee RZ7 Varia Seat Post Mount - http://shpws.me/SUJD
Giant TCR Advanced Varia Single Bolt Mount (MY16+) - http://shpws.me/STmj
Giant Defy Advanced Varia Single Bolt Mount (MY16+) - http://shpws.me/STmd
Hey Waldo,
When I bought some Blendr rear light saddle mounts for my Pro Stealth saddle from you, I recall you showing a longer version but I can't find it. Do you still offer it?
- Resident master of GIF
- Contact:
hey waldo long time! anything for the tarmac 0 offset seatpost 'cover'
Bud,
Any progress on 3D printing mount adapters for the Hammerhead Karoo2?
Something like this....
https://www.shapeways.com/product/D8H49 ... arketplace
My issue is that I want to replace the Garmin quarter turn puck on my Enve mounts...but there's a center countersunk m3 bolt and the tab on the side which prevents movement or twisting within the base mount.
- Factor Ostro VAM Disc
- Factor LS Disc
- Specialized Aethos Disc
- Sturdy Ti Allroad Disc
- Guru Praemio R Disc
- Factor LS Disc
- WheresWaldo
- in the industry
Have been busy, but I will try to answer all questions:
- @BdaGhisallo try http://shpws.me/Sdfo
@nathanong87 no one as asked before and I don't have a reliable source for Specialized bike parts, had a falling out with the local shop as they were not reputable.
@kode54 nothing as I don't actually have a model of the Karoo2 mount
I can send you a Karoo2 mount and an Enve mount if you need it. Not sure if any Karoo adapters are available on Thingverse or other CAD sources. LMK if you need to have the physical parts.
- Factor LS Disc
- Factor LS Disc
- WheresWaldo
- in the industry
@kode54 I try very hard not to use anyones models. All but one single model in my Shapeways shop is 100% mine. I have seen the stuff on Thingiverse and other file repositories and try to avoid them like the plague. Although I have posted a few models on Thingiverse myself, mostly 3D printer and bicycle tool related.
If you want to discuss the Karoo 2 mount further, DM me.
