Camera Mounts and Assorted 3D Printed Parts
- WheresWaldo
- in the industry
@kode54 here you go, http://shpws.me/Qezq
It has a tapered hole that requires you replace the center screw with one that is 3 mm longer. You will need to let the screw 'cut' its own threads into the nylon. I am not concerned about holding together as the Junction A Box is pretty small and light even in the 5-port version.
that's excellent. i ordered 2 of them. yes...the junction A is very light. insignificant in weight.WheresWaldo wrote: ↑Thu May 03, 2018 9:46 pm@kode54 here you go, http://shpws.me/Qezq
- Factor Ostro VAM Disc
- Factor LS Disc
- Specialized Aethos Disc
- Sturdy Ti Allroad Disc
- Guru Praemio R Disc
- Factor LS Disc
- WheresWaldo
- in the industry
@kode54
Let me know how well it works out and if you wouldn't mind either posting or sending me a picture of it in place I would really appreciate it.
sure. absolutely. thx again.WheresWaldo wrote: ↑Sat May 05, 2018 11:55 am@kode54
it is in the process of 3D printing. will get in a week according to Shapeways timeline.
- Factor LS Disc
- Factor LS Disc
- WheresWaldo
- in the industry
Something new to add to the collection. If you are a GoPro user and regularly carry the GoPro remote, here is a mount for the remote that twists on to a Garmin quarter-turn mount. It isn't up on Shapeways just yet, still waiting on the requester to say okay with the design.
https://a360.co/2IoOT1Y
Would anyone be able to design something like the below but for a 25.4mm post?
- WheresWaldo
- in the industry
Do you want to just duplicate the mount parts? Is nylon okay or does it have to be aluminum? Can it just be one part that snapsin place or do you want it to be two parts like the original? If it's like the original are you willing to use the same hardware?
Sent from my SM-G965U using Tapatalk
Two parts like the original to ensure a tight fit would be ace!
- WheresWaldo
- in the industry
@DartanianX I will have something later today
- WheresWaldo
- in the industry
@DartanianX How is this?
Image removed to save space
I had to make the assumption that the bolt provided is M5, but if it is smaller let me know and I will adjust the model accordingly. It is not quite as thick in the middle to save some raw material costs, I can thicken it if I know just how thick the middle section of the original mount is.
- WheresWaldo
- in the industry
So @DartanianX are you no longer interested?
On another note, a department at BMC Switzerland just bought themselves my Wahoo Fitness BMC Stem mount. I don't exactly know how big that department is, but it is more than one. I hope it is to use and not to reverse engineer and come out with their own version.
Sorry, have been away traveling the last few days. I’ve PM’d you.
- WheresWaldo
- in the industry
Exposure Blaze 25.4 mm Seat Post mount is done and up on my Shapeways page. It looks pretty much exactly like the aluminum version and will use the existing hardware. It is here: Exposure Blaze 25.4 Seat Post Mount
Please note that the Black Strong and Flexible finish is not polished and will have a grainy/fuzzy surface texture. The Black Premium Strong and Flexible is finished with a multi-step tumbling, polishing and dyeing process. The result is a much smoother surface, ideal for products that require a finished look and feel. The Black Premium finish has an eggshell sheen.
- WheresWaldo
- in the industry
@TonyM
What are you thinking exactly? I reviewed the Campy Assembly Manual (https://www.campagnolo.com/media/files/ ... _04_17.pdf) and it shows that Campy didn't really make a mount for it but rather relies on an O-Ring to mount the unit. How and where do you want to mount yours?
It looks like Campy units IF12-xxxx (2012/13), IF13-xxxx (2012/13), IF-14xxxx (2014/15 V2), IF15-xxxx (2015/16 V2), IF16-EPS (2016+ V3) all mount in the same manner.
