Garmin Out-in-front Mounts Ad Nauseum
otoman
by otoman
2focused wrote:
Fri Sep 08, 2017 5:29 pm
Anybody make one for Easton EC90 SL stem. have the aero bar and with kedge it wont fit. If I cant use the Easton stem I'll go zipp sprint
Bump...
Any one point me in the right direction?
Age and treachery shall overcome youth and skill
slake21
by slake21
if anyone needs a 27mm edge mount for cheap, let me know. I have one that I don't use anymore.
ebsilon
by ebsilon
Hi All Image
If any of you have the Thomson X2 Edge Mount I am interested in buying it.
Morten says he will not make a production run of I any more Image
Are there any alternative to the X2 mount?
It has to bu centered in the middle of the stem and using one of the bolts for attachment.
Are the any carbon mounts out there that will work?
Ciaoooo
Moller
Speed of Lite
CarbonWorks
by CarbonWorks
Hi :D
we have CarbonWorks Cockpit Mount optimized and finally available.
1. The side panels are made in black anodised aluminium instead of plastic now.
2. The small round parts (inserts) with the threads are made of stronger material than before.
3. The cockpit mount comes in an exclusive magnet-box
4. It is longer and compatible with the Garmin 1030 now.
If you guys have some feedback, I would really apreciate it!
You can always send an email to me:
simon.buehler@carbonworks.de
Thank you,
Simon
Simon
carbonworks.de
Spinnekop
by Spinnekop
CarbonWorks wrote:
Sat Jan 19, 2019 4:18 pm
Hi :D
Thank you,
Simon
Awesome news, thanks Simon. Was hoping you guys are working on the 1030 option.
Will see if I can organise one via a friend in Germany. He is visiting us in SA in March. Free shipping. :lol:
"In my experience, there is only one motivation, and that is DESIRE.
No reason or principle contain it or stand against it........"
markdjr
by markdjr
Hi :D
Thank you,
Simon
Does this mount work ok with Enve road stems?
garjo
by garjo
New Extralite mount for hyperstem is ready! http://www.extralite.com/Products/HyperStem%20CH-01.htm
At 99 € I think is one of the most expensive mounts out there, even if not the prettiest.. imho they could make a simpler out front mount, instead they did complicate it uselessly (it should have used exiting clamps not new ones!), making it too expensive.
My 4,93 kg Supersix Evo HM: viewtopic.php?f=10&t=137647&start=30
My 6,22 kg Cannondale R500 1996: viewtopic.php?f=10&t=134364
1sanglier
by 1sanglier
Is some one knows if it exist a support for Wahoo Element bolt, Aero like original Wahoo support but fix on stem by the 2 screws ?
RyanH
by RyanH
Does anyone know how the Tilquist mount gets along with a -17 stem? I noticed my current stem mount (Alptitude) is pointed down on a -17 but level on a -10 stem. Fetha is another option but I think there's is on the long side for a Garmin 130.
markdjr
by markdjr
Sorry if this has been covered, are there any compatible stem mounts for MCFK? Thanks for any info.
silvalis
by silvalis
Does anyone know if a K-Edge Garmin mount in regular or XL will reach the centre of a Zipp Speed SL stem? Not sure if it's the same width as a zipp sprint stem.
alternatively, the barfly, same question. Or a bolt mount that can support a gopro/light hanging off the bottom
Chasse patate
silvalis
by silvalis
If anyone cares -
K-Edge XL on a Zipp SL Speed stem / Zipp SL70 Aero bar does not fully centre the Garmin.
~3 or 4mm off. Enough to be noticible.
Chasse patate
sfo423
by sfo423
Looking for an outfront mount for a 520 plus; I am using the oem Garmin mount and I'd like the head unit closer to the stem; but not so close you cannot press the start and lap button.
anyone have a mount suggestion for the above scenario?
bigfloor
by bigfloor
bigfloor
by bigfloor
It’s kind of adjustable, uses distanceholders that could be shortened (do need to shorten the bolts as well)
I use this one for my Garmin 530 and Hammerhead Karoo
