Gloves for minus degrees weather
Kit Brand Talk. Everything under the sun, including sunnies!
Brabus
by Brabus
There's ton of variants for winter gloves, but most "winter" gloves are meant for 0 to 5c weather, can anyone recommend something that is meant for proper winter ( -5 to -15c ) ?
jayjay
by jayjay
I have 2 pairs from Assos. "Winter gloves" and I think "Ultra winter gloves". At 0° the Ultra gloves are still to warm for me.
Obviously cold hands is pretty individual.
kervelo
by kervelo
IMO the Assos apparel are not warm enough for the nordic winter weather, as they have been designed for the central european winter conditions. Roeckl makes some warm gloves that I have used when the temperatures are below zero:
Roeckl Villach 2
https://www.roeckl.de/#Multi:B2C/article/10/10-110031
Roeckl Villach 2 Trigger
https://www.roeckl.de/#Multi:B2C/article/10/10-110044
Even with these gloves your hands will eventually get cold, if the temperatures are -15 C.
Mr.Gib
by Mr.Gib
kervelo wrote:
Fri Oct 25, 2024 9:40 am
Roeckl Villach 2
Don't know this brand, but if you're from Finland, you have automatic winter cred. But allow a Canadian to contribute. Working from the assumption that extreme winter riding is zone 2 or lower, Keeping hands warm will be tough. If looking for a single item to deal with the cold, it would likely be best to choose from any number of ski gloves designed for those temperatures. Alternately, I would recommend a combination of under-gloves with a windproof lobster shell on top. A good combo would be a close fitting thin polypropylene knit glove under a heavy fleece or wool glove with the shell on top. Then slide a chemical handwarmer inside the shell glove. Dexterity will not be great but comparable to heavy ski gloves and you have the option of removing layers if things heat up. Sportful makes a nice lobster shell - https://www.tradeinn.com/bikeinn/en/spo ... lsrc=aw.ds
kampiakseli
by kampiakseli
Last winter we had period of -20 to -30 and these were gloves that saved my outdoor cycling:
https://lenzproducts.com/en/products/he ... er-cap-men
I have had heated sock from same suplier for long time...
pdlpsher1
by pdlpsher1
How do you clean electrically heater gloves? I use my gloves to clean snot and they get really gross.
kampiakseli
by kampiakseli
I don't clean them. Outside they never get dirty, because I use them only on cold weathers (dry ice and snow don't make mess). Inside the gloves, my hands won't sweat on those temperatures...
MrRolandos
by MrRolandos
Castelli estremo are my go to when its really cold
https://www.castelli-cycling.com/NL/en/ ... 9_010_02_L
When im doing easy mountainbike rides, I sometimes combine them with assos spring fall liners for a double layer.
Ive tried multiple options, get cold feet and hands easily but this just works
JoO
by JoO
I live in Belgium. Winters are not super cold, but wet and I have cold hand very quickly.
I have 4 pairs of gloves to suit the situation.
I can't use gloves with separate fingers if it gets cold. I tried so many brand.
Crab/lobster style mittens are the best for me.
When is gets really cold. Ski mittens from decathlon, but I risk sweating/overheating in those.
covfefe
by covfefe
I also live en northern europe and are riding all year outside. Rapha have some deep winter gloves, that go down to around a couple of degrees minus celsius. If it gets colder than that, I just turn to my mittens. Obviously the dexterity drastically reduces. But good quality mittens with thin inner gloves makes it easy to remove the outer while riding, and performing tasks with just the inner glove like reaching into your pockets etc. It also has that advantage, that it's possible to adjust for temperatures by using different inner gloves. Some warmer than others. Because it actually is a big difference, if it's -5 or -15 degrees celsius.
uppis
by uppis
45NRTH Sturmfist 4 works well below -10c for me. https://www.45nrth.com/products/gloves-pg256.htm
Spurdo
by Spurdo
Tried various gloves, lobsters, mittens and whatnot with and without liner gloves without much success and while I hate the look bar mittens just work.
zirxo
by zirxo
I usually wear something like this, picked up from big bins at your nearest sports goods store. When it gets below -10 something I usually add some think liners in the gloves, although I don't ride more then like 3 hours if it's that cold.
https://www.xxl.se/bula-alpine-gloves-m ... 89_1_Style
MarkoP
by MarkoP
MrRolandos wrote:
Sat Oct 26, 2024 6:44 am
Same here - these are excellent.
Only when it gets ridiculously cold (and then I rarely ride outdoors) I have a pair of lobster gloves which I pair with thin merino gloves underneath.
Current: 2021 Bianchi Specialissima I 2021 Tarmac SL6 S-Works (Sagan Edition) l 2023 Aethos S-Works l 2024 Lauf Seigla Rigid
poulhansen
by poulhansen
I use Ekoi electrically heated gloves. They are a plus when it's cold. Only niggle is that I'd like more heating threads at the point of the fingers.
Cannondale Super Six Hi Mod 2017 6.845 kg
Cannondale six13, 2004, 5.50 kg
Focus Izalco Max, 2023, 4.33 kg
