Hi there,
I just bought a second hand commuter bike with Sram G8 hub gearing. The seller told me something is wrong with the shifting but he wouldn’t bother trying to fix it. So I just thought I’ll give it a shot. Problem is, that it does not shift into the three highest (lightest) gears (gear 1-3). From 4-8 it shift perfectly well, when I go beyond 4 to 3 the gear gets really low (more resistance than in gear and this does not change for gear 1 and 2. In other words, gear 1-3 are the lowest gears by feel with no difference, when I shift into gear number 4 it seems to be just right and from 4-8 it seems to work well (even though gear 8 seems pretty high, a lot higher then 1-3).
Any idea what the problem could be? I figured that the shifting seems vice versa than on a normal groupset (I’m normally on road bikes) which means you shift into the lower gear with cable pull.
Thanks in advance for you help!
Kind regards!
SRAM G8 hub does not shift into the 3 lightest gears
Cannondale SuperSix Evo Disc
Cannondale SystemSix HiMod Disc
@floriansantana
@floriansantana
